Question about Philips Magnavox DVD/VCR Dual Player
I have a Magnavox dvd player MDV412/17. I took the cover off. When I push the open button the quarter sized botton drops a sixteenth or so but i have to tap it to make it open. It closes fine. Is there a way to lube this or what may be the andswer. k.coleman
SOURCE: Help with Magnavox MWD200F
The lense is proaly gone or mechanism disrupted
Posted on Feb 27, 2007
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: the DVD player is saying there is a disc error
it either means that you need to clean your disc(s) or there is something loose inside making it malfunction
Posted on Dec 17, 2009
caroldon
  • 17130 Answers
SOURCE: Philips DVD 622 ... Tray
Possible that the mechnism is jammed or the drive control is not working or the loading motor is not working.
It will be good to remove and check for mechanism movement with a manual action, check the motors and then check to see if the logic works from teh processor when the eject is presssed. If not the control board/motor drive is faulty.
Posted on Sep 28, 2010
ekmoetweet
  • 124 Answers
SOURCE: The DVD gets stuck inside
Open up the dvd player (first unplug) by loosening screws on side and back take out disk and clean round spindle the disk is sticking too.
Posted on May 11, 2011
I have a sanyo dvd/vhs player and when you push the eject button to eject the dvd player it won't open. Help!
If you take off the top cover you might find that a drive belt that moves the tray is either off or broken. They are cheap to replace you just need to measure the diameter in MM and then enter "drive belt XXmm" into Google go for the nearest size to your measurement.
Jan 18, 2013 | Panasonic DVD-A110 DVD Player
Magnavox mdr515h/f7 will not display video or audio. Was working fine before today.
After reading all the above I took my cover off and found the little fuse. I removed it and it tested ok. I had called Magnavox and they told me there is no fuse or anything like that. I took one last look before throwing it in the trash and there on the circuit board is a little button marked reset. I pushed it and now it works again. So there is both a fuse and a reset button.
Feb 25, 2012 | Magnavox MDR515hf7 Player
The dvd open/close will not work. It does not open or close when pressed by wither remote or manually.
Mine does the same thing, it appears there is a white plastic piece of the track that slides is broken. If I take the cover off and look in the front right hand side I can push it with a pen while pressing the open button and it works. Now if I could replace the plastic piece I would be all set.
Dec 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When the open/close button is push , the DVD tray open and it close immediately without pushing button.The tray won't stay in the open positions.
check the close circuit switch inside the system. its maybe stuck, try to wiggle it a bit and it might work again.
the switch is at the end of the tray when it is closed, its a small black push botton swith.
be careful not to fry it when installing a new part
Aug 26, 2010 | JVC HR-XVC16B DVD Player / VCR Combo
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The DVD will not stop spinning. The door will not open either. When I took the cover of the players and plugged it in, the DVD just keeps spinning even when I hit STOP, OPEN, and turn the player OFF. ...
I've had this problem twice now.
The first time, I unplugged the unit for about a minute, plugged it back in and pressed the Open button. The disc was ejected and ran fine for about a week.
Then it happened again, but the unplugging didn't fix it this time.
Try this;
Unplug the unit and let it sit for a few mins to let the disc stop spinning. Then gently pull down on the DVD door. Look at the lower left side of the DVD tray and you should see a large slot. Shine a light into the slot and you will see a dime size white gear. I used a small flat head screwdriver to spin the gear to the right. After 2 small turns, the DVD tray opened enough so that I could pull it gently open. I took the DVD out, gently pushed the DVD tray back in and set the DVD player on my workbench to tinker with on a rainy day. Not sure what the root cause is, but I'll worry about that later!
Aug 14, 2009 | Samsung DVD-R135
Door to open dvd seems to be stuck
try turning unit up side down and try again.
Mar 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Remote Buttons
Press the VCR button first then press open/close
Nov 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
