Question about Baumatic Microwave Ovens
My baumatic electric hob is flashing "er22" and will not work
Gas rings will not light because of no electric spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Baumatic Microwave Ovens
I have a GECE7006 induction cooktop and next to the timer button it is flashing "Lo" and i cannot clear it to use any of the hotplates?
Remove the main power for about few hours and then plug the unit while you press the Start/Stop button. If the panel still blinks around, check for any traces of moisture on the panel. if so dry and check. If not the processor is having some errors which needs to be checked from within and requires Tech help.
May 19, 2011 | Baumatic Microwave Ovens
My gas hob works fine,but my electric ovens have gone off,i am getting electric power but they wont come on
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 21, 2011 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
I"m looking for a wiring
The closet model number I could find was the BT83Al which is a discontinued model. At teh follwoing site you can download a User Manual and Technical Drawing.
http://www.baumatic.co.uk/bt83al_21_106_550.html
If this is not your model other discontinued models can be found here:
http://www.baumatic.co.uk/cooker_hoods_21_106.html
Current Models:
http://www.baumatic.co.uk/cookerhoods.html
Feb 11, 2011 | Baumatic Microwave Ovens
How do we replace the light bulb in our Baumatic BTM25SS microwave oven? It seems to be inaccessible....
From Baumatic:
"Unfortunately, the bulb is positioned next to the main working component of
the microwave. This means only a qualified domestic appliance engineer,
trained to work with microwaves can carry out such a repair. If you wish to
have a Baumatic engineer attend, please contact the Baumatic Customer Care
team direct on 0118 933 6911. If, however, you wish to purchase the correct
bulb and have a local engineer carry out the repair, please call the
baumatic Spares team direct on 01235 437 244 for price and delivery
information."
Nov 20, 2010 | Baumatic BTM25SS Convection Microwave Oven
How to replace bulb in baumatic btm25ss microwave oven?
Had the same problem. From Baumatic:
baumatic Spares team direct on 01235 437 244 for price and delivery"
information.
Apr 17, 2009 | Baumatic BTM25SS Convection Microwave Oven
Microwave Ovens Logo
Top Baumatic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Baumatic Microwave Oven Expert? Answer questions, earn points and help others
