Question about Intel Motherboard
No sound damage - Intel Motherboard
    Sergeant:
    Champion:
  • 236 Answers
Go to the control panel and click on system icon and look in teh device manager for your sound card. Make sure that is not a yello exclamation beside it. You can then right click and reinstall the driver. See if that helps
Posted on Mar 19, 2011
How do I get sound and color on model P50W38p Zenith Tv
Hello Robert
It is supose to have sound and color, or instead, its damage board.
I will recommend you to visit your local dealer, or tech, and tell about this particular issue. For me , its a damage board. but like I say, all these things will be better be watch, with a tech.
other than this will be:
1) damage board/sound board
2) bad capacitors in general board.
Jan 30, 2017 | Zenith Televison & Video
Tip
Sound damaged causes
no sound mean: <br /> <br /> 1- speaker is bad <br /> <br /> 2- entrance sound is bad <br /> <br /> 3- driver is bad ( re-nstall)<br /> <br /> 4-windows had a damged files (re- install)<br /> <br /> 5- sound ic control is damaged ( need out pci/ usb sound card ) <br /> <br /> 6- tow jumper in mother board are take off<br /> <br /> best regardes
on Mar 28, 2011 | Computers & Internet
It went in for service when we got it back it only turned on once. now when we turn it on the screen is black and on the top left corner the cursor is flashing and if you press on a key it makes a loud...
There are two possibilities, damaged memory and hard drive not detected or damaged. Most likely is, the hard drive is not detected or damaged. The characteristics of the hard drive is damaged, when you turn on your laptop, you are like the sound of this
To be sure, the hard drive is in trouble, press F2 to enter BIOS, check your hard drive, or check the hard drive is detected or not.
If the hard drive is not detected and didn't sound the hard drive is damaged (like in the video), the hard drive can be repaired and the data can be saved. Solution: take it to the Service Center.
If the hard drive is not detected and the sound of damaged hard drives, optical damage your hard drive. Solution: replace the hard drive.
Sep 23, 2011 | Computers & Internet
No sounds coming from pc to speakers
hi
plz follow steps dear
1- be sure the driver is instaled
2- also you re-install windows some times file of windows is damaged
3-if all ok and still no sound may be bulte in sound is damaged
4- you can add sound card out
5- plz send me mother board photo
wish you resolve
Mar 25, 2011 | Computers & Internet
Playing keyboard and the polyphony is suddenly reduced. Is it possible to overload the sound card?
Inspect the devices sound producing effect buttons. For example, ascertain the volume button was manupulate accidentally durng ketboarding. Readjust the volume to attain desireable effects. Inspect the connection cables for maladjustments causes. Reconnect any unpluged cables making sure firmly in place to achieve louder sound. Usually sound cards least get damaged during device functionality. The noteble malfcuntions with sound cards are fluid encounters on the cirucits during usage that causes burnouts due the cuicuirt generation of heat or embeded at the heating area of the device. Sound cards may malfunction either caused by impacts maladjust the situation on the circit board. Also soundb cards malfucnion either as impact damaged where the device were droped or encounter collsion with another device causing scraches or breakage. The condition of damages sound card may require to replace entirely to new acquirable.
Feb 07, 2011 | Yamaha Portable Keyboard
Speakers are not working in dell inspiron 6000
Please connect an external speaker or headphones and check if you get sound. If sound works then the issue is with the onboard speakers in the laptop.
If sound does not work with the external speakers or headphones then the issue could be with the sound card driver or settings.
Dec 25, 2010 | Dell Computers & Internet
My sony KV-G21PD1 sounds are not working
Hello
Either your TVs internal speaker or its sound output Ic has damaged. You can make sure about which part is damaged through the following sugession.
Just place your ear, very close to the TVs speaker side, and switch on your TV with its front panel power switch, not by the remote control. If you can hear a 'thumb' sound or 'HUM' sound, you can make sure that the speaker is ok. If you hear a 'HUM' sound as describe above, make sure that its sound output Ic has damaged. If the sound output Ic has damaged, sometimes you may not hear any sound at all too.
Connect the TVs audio out RCA scoet to an amplifier, if you have, and try to get the sound through it. If there is sound through an external device, make sure once again that the internal sound output Ic has damaged. Speaker can be checked by a torch cell, connecting its terminals to the two leads of the speaker, with two pieces of wire, just intermittent touch, you can make sure that it is ok or not.
To replace the sound output Ic, you must open your TV, and locate the sound output section inside it. It is easy, to do, just follow the speaker wire, and find it from which point from the main board it orginates. Somewhere near to it, you can loact this Ic.
Before replacing the Ic, just measure whethere there is voltage comes to its supply terminal or not. If there is voltage, and no sound at all, replace the Ic with same type and number without any doubt.
If there is no voltage comes to the input pin of that Ic, check the track leading voltage to that point, and find whether there is any resistor has opend or not. Ok
If you need any further assistance, contact me through Fixya.
OK.
Nov 26, 2010 | Sony KV-27S15 27" TV
Sound not coming
Hello
You have reported that there is a sound problem for your TV. I don't know you have tried all the options in the sound menu of your TVs user manual, you haven't stated anyting about it. Anyway I assume that there was sound, and it has gone now only and send this solutiion.
Just connect the audio out socket on the rear of your tv, to any audio devices you have, an amplifier or so, and check whether cound comes from that device or not. If there is no sound from that device, it means that something has gone in trouble with your TVs sound filtering system, which is integrated on the printed circuit board inside and you must have skill and through knowledge about soldering, and to follow the circuit schematic digram.
If there is sound now through that device, means either your TVs speaker has damaged or its Sound Output Ic is damaged. If speaker is damaged, it can be easlyto replaced with an identical one. To make sure about it, you just place your ear very near to the speaker side of your TV, and switch ON it by AC MAINS. You will hear a small "Thumb" sound if your speakers are Ok. If there is no "Thumb" sound you can make sure that the speaker is damaged. If you hear a "Hum" sound, it means that your TVs Sound Output Ic has damaged.
You just check these, and report the result to me through Fixya. Since you have given a small description about your TVs fault; with two or three words, how can I get to the exact point of fault. Give me details as much as you can an you know. Ok.
Nov 03, 2010 | Philips 30PW8420 TV
No sound when i answer my cell, I can only use my headphones or put it on speaker. So is the sound card damaged or do I need to load a sound program back on it?
Earpiece may have been damaged or dirty. It is advisable to have your unit checked by a qualified cellphone technician to avoid further damaged.
Oct 15, 2010 | RIM BlackBerry Curve 8520 Smartphone
Sound cards
no it will not be damaged because of 2 sound cards.The computers will detect them both.
Jan 03, 2008 | Computers & Internet
Intel Motherboard Logo
13 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
