Question about Peavey Xr 8600 8 Channel Powered Mixer
I have the peavey 8600 and l was doing karaoke at my bar last nightwhen something weird happend. i plug my karaoke eqpment into the last channel at the rca in and last night that channel lost half its power for some reason. i changed channels and it worked fine. i moved it back and it done the same thing. WHATS WRONG my xr 8600 is less than a year old.
  • Peavey Master
  • 5,603 Answers
Iis ALL your equipment powered from the same receptacle? It had better be... ground bounce can destroy input circuits in these units. I don't have the schematic but a common problem where XLR connectors go into a mixer is they have radio-frequency noise suppression caps to ground from each side of the XLR input. These caps are often lower voltage rating and can be popped by ground bounce or ungrounded equipment being connected before the ground connection is made. When one goes, there is loss of half the voltage or 6 Db of power gain. Since these RCA's are right at the XLR they MAY connect and have these caps and one may have shorted. That means the repair shop I am afraid unless you are adept at electronics. Most of these mixers are a pain to work on that area as all the knobs and screws have to come out/off to get the circuit board away from the panel to work on... I wish I had the service manual to give you more info...
PLEASE in the future power all equipment from the same receptacle or power source AND for units that don't have three wire power cord, NEVER change cables that can break the ground connection such as the RCA cables while power is on to any of the equipment. This will save repair bills...
This is from your friendly electrical engineer that works with this stuff and repairs his own...
Posted on Mar 19, 2011
Have a Peavey XR 8600 we use it with 4 speakers in a riding arena. It works for a few minutes and cuts out.
It depends on if this is a new problem on a previously working system , or if it's been going on since it was first plugged in, but geneally speaking it sounds like your impedance load is too low on the amp and it's overheating. I would double check that, but if the load is in line with the specs, it needs to go to the shop. Contact Peavey to get the autorized repair guy in your area, or you can send it to them to do inhouse repairs. They are reasonable and have access to all the needed parts, but you'd have to pay to ship it in and back.
https://peavey.com/support
Oct 18, 2016 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey XR series 600 may have been left on without one speaker plugged in, what is the likely diagnosis?
Out put amplifier is defective. If it was protected by a fuse - then look for a fuse that is blown.
Sep 27, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Hello, I am new to forums, this is my first time. I have a Peavey 696f power mixer, last night the left speaker channel stopped working, what do you think is causing this problem?
the pa1 or the pa2 input jack on the front of the unit is dirty, or you have a cracked solder somewhere, as these units are gettting old.
Jun 18, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I have a Peavey amp but no sound is coming out?
Bad output transistors or bad Soldier joint in output section
Nov 26, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
How do i hook a peavey fx24 mixer to a Peavey xr8600 with out going through the 8600's mixer? I am wanting to use the 8600 to power my mains and use another amp to power my monitors. can i do this?
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
Sep 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I use my Peavey XR 8600 with an acoustic duo that I'm in. At my last show, an audience member grabbed and dropped a vocal microphone that sent a sharp sound through the Peavey and shut it down. When I...
Chances are one of the power amps has shorted. Replacing the fuse probably fried additional components. Unless you are electronically adept this is NOT a DIY repair.
Expect that this is going to be an expensive repair as often quite a few transistors and other components fry when one goes in these power amps.
Mar 09, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I want to use both speaker outputs for loudspeakers on my Peavey 8600 without splitting the watts. How do I hook up monitor speakers in this situation? Can another mixer be patched into the front? I have...
Sorry, but this unit does NOT support "bridged" mode. You will have to drive seperate speakers from the two seperate outputs. You would NOT get any more power if you could do bridged mode than you could with 4 ohm speakers on each of the two output channels.
Nov 27, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey Xr 8600 8 Channel Powered Mixer Logo
222 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
