Question about Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Dishwasher
Bosch SHX33A: lights come on properly in response to buttons, it has power. Close door, it makes the normal startup sounds, then water flows in. Normally, at this point washer starts into normal cycle. Instead, it just sits there and nothing happens. Forever. Not a matter of patience: we've left it in that state all night long. Have flipped power circuit and started over, everything else I can think of to kick-start it, no change.
  • 2 more comments
  • jim_upchurch Mar 19, 2011
    Fortunately cancel/drain combo works so at least I'm able to get the accumulated water out. If the issue I'd motor or bad door latch, I guess I'm down for a service call anyhow.
    Far as sound and feel and initial functionality, the door latch is working OK. I don't guess that rules out some other issue with it, though.
    Any other test I can run to establish exactly what's wrong?
    When you say "it works" what are you referring to? The cancel/drain button combination? That would seem to require some pumping which seems to suggest motor might be OK?
    Any idea - ballpark - how much a timer replacement costs, parts
  • 4,323 Answers
Hi
The issue seems to be with the motor or the door latch assembly going bad and should be replaced. The washer won't start the cycle if motor is not working, as its filling with water so I believe that the door is fine and it is the motor that is causing this issue. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 19, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott Mar 19, 2011
    If it works however it wont start a cycle then it is the timer that is bad
  • Daniel Scott
    Yes right thats what I mean...if the drain pump is working so the motor is fine rather it is the timer that is bad and should be replaced
  • Daniel Scott
    Around $100-$150 for parts and you can add on labor charges if you get this done by a tech
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Bosch shx33a starts, fills, then stops. Drains OK when forced to end cycle.
I know this may sound very silly but i had the same problem with mine and all i had to do was pull it out a bit as the drainage pipe at the back was only slightly sqashed against the cupboard but it does matter
Sep 13, 2012 | Bosch 24 in. SHX33A05 Stainless Steel...
The clean light flashes 7 times. This started after a power outage.
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
New SHE4AM16UC, professionally installed eight months ago. Worked fine with very light usage until now. Dishwasher starts normally but stops and signals "clean" after less than five minutes on any cycle....
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 05, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Cleanlight blinks and wont let you do anything turn off power and still the same
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 02, 2009 | Kenmore Dishwashers
Bosch dishwasher model shx33a can't figure out how to just drain without running the whole cycle...HELP
usually on the consol in small print it will say press these 2 keys to drain. Read all the lettering on the consol and let me know
May 28, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
My clean light is flashing....call service to check heater?
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
My Bosch Dishwasher doesn't run
double check power to your plug socket ( use bedside lamp)
check fuse in plug
check water supply ( run the water supply directly into pot/bucket)
make sure door closes properly (if built in )
if built in remove and then check!
Feb 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Open Questions:
See all Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Questions
Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Dishwasher Logo
85 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
