Question about Dryers
How to replace a belt on this style dryer, is there a trick
  • 2,510 Answers
REMOVE THE SOCKET FROM THE WALL OUTLET.
To replace a belt that passes over the drum on a dryer you need to be able
to pass the new belt over either the back or the front of the drum. This
entails removing the front panel to clear the whole drum or loosening off
the rear bearing support to pass the belt under it so that the belt can be
passed over the drum. From there it is just a case of passing the belt
over the motor pulley and replacing all the parts. Select which will be
easier on your machine. After replacing everything but the top panel,
make sure that the belt is correctly installed by turning the drum several
revolutions by hand and ensuring that the belt is running true and still
on the motor pulley. Tension the belt by either adjusting the motor or the
tensioner, if the machines has one of those. Replace the top cover and
you are set to go.
Posted on Mar 19, 2011
Is there a diagram of how to run the belt on the tensioner, have new belt around drum already. Don't know what it is suppose to look like. Thanks Dave Ball at (the.49er.miner@gmail.com)
Man Im not sure if this info will help you but. On my dryer which is pretty much the old style, standard type dryer and I had to replace the belt and had a little trouble putting it on the tensioner, finally figured it out.. If you take the belt and pinch it together and pull under the belt tensioner and then around the moter shaft that's what you do for the dryer style I have.. HOPE this may HELP!!
Jun 20, 2011 | Samsung DV218AEW Electric Dryer
Tip
Kelvinator Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Tip
Gibson Dryer Belt Diagrams and Replacement
Style: Flat belt
Do you have a digram to show you how to change belt on inglis dry
amana.gif Diagram A
transparent1.gif frank.gif Diagram B
transparent1.gif frig.gif Diagram C
transparent1.gif ge.gif Diagram D
Installation Tips: Ribs against drum
transparent1.gif maytag.gif Diagram E
Installation Tips: Flat side of belt against drum
transparent1.gif admiral.gif Diagram F
transparent1.gif westing.gif Diagram G
Style: Flat belt
transparent1.gif whirlpool.gif Diagram H
belt1.gif Diagram J
belt2.gif Diagram K
belt3.gif Diagram L
belt4.gif Diagram M
Jun 25, 2009 | Whirlpool Inglis IP8200 Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Tip
Hotpoint Dryer Belt Diagrams and Replacement
For Hotpoint Dryers
1970- 1990 standard capacity
1970- 1990 Large capacity
1990 – to present
1b9906a.gifStyle: Flat with ribs
Tip
Kenmore Dryer Belt Diagrams and Replacement
For Kenmore models starting with 110 or C110 with a removable back use this:
For dryers starting with 110 or C110 with nonremovable back use:
For Dryer models starting with 417 use:
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
For 1985-1995
For 1995- present
Style: Flat belt
For Ge Dryers
1990 – to present
on Mar 02, 2010 | Dryers
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
For Amana all models will look like this
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Dryers Logo
315 people viewed this question
Top Dryers Experts
