Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
How to delete User fault codes
How do I remove/delete the user fault code from my dish drawer - Specifically the U2 code - The code comes on although the drawer is closed - There is no one here that would force the drawer open in a cycle - We would just like to disable/remove/delete the User fault code - Can this be done? If so, how? - Thank you for your help -
  • Anonymous Aug 11, 2008
    flooding
  • Anonymous Aug 26, 2008
    Is this also related to the seal, i.e. if the seal was defective would this error also come up?
Hi
I have the same problem as above with the u2 fault coming on at the start of the cycle. Can you please email me advice? katedperrone@yahoo.co.nz
thank you so much!
Posted on Feb 28, 2010
  • 770 Answers
Yes what is your email so i can send you the tep by step
Posted on Aug 03, 2008
U2 Fault cde displayed at start of wash cycle
The reason for U2 fault code in your dishwasher is due to the problem caused beacuse of loading. Check loading to ensure no items extend beyond the height of the drawer.
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I HAVE A TWIN DRAWER MACHINE ABOUT 5 YEARS OLD THE TOP DRAWER IS WASHING DISHES BUT LEAVING WATER IN THE BOTTOM OF THE DRAWER WHICH I AM NOW HAVING TO EMPTY MANUALLY HOW CAN I FIX THIS PROBLEM
Have you tried running the rinse cycle to check if the water drains out?
If you are not getting any fault codes, then it might be simply a matter of cleaning the base filter plate and the sump. The user manual will tell you how to do this.
If that does not help then post a comment along with the model number of your fisher and paykel double drawer unit and I will suggest further diagnostics.
Jan 29, 2010 | Fisher and Paykel Dishwashers
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
TOP DRAWER WAS NOT DRAINING..NOW THE F1 ON BOTH DRAWERS IS ON
F1 code indicates a leak,you will find the water under bottom drawer.Lid probably not sealing well.
Jun 17, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
U2 fault code?
Hi there, Error U2 -
Possible Causes - Loading
Good Luck!
neo
Feb 27, 2009 | Fisher Dishwashers
U2 Error Fisher Paykel dd-602 dishwasher
Good Luck!
neo
Sep 01, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Double Drawer Dishwasher
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
Jan 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F & P Double Drawer
Are you sure of the model?? flash a U3 the following is from The FP Manual on the DD-603 Model...........
Water not draining from drawer
Could be the little non return valve mounted underneath the top drawer. Lie down on the floor under the top drawer, remove the main plastic pannel covering the bottom to expose the black drainage hose (you may need to cut away a cable tie). Remove the drainage hose from bottom of the drawer - at the start of the drainage hose there will be a small rubber type flap - if it looks broken or worn out, it will need replacing - call F & P for a replacement, approx $5 + postage for a pair (one for the top drawer and one for the bottom)
Hope this helps
Nov 03, 2007 | Fisher and Paykel 24 in. DD-602 Built-in...
U2 fault code?
Aug 13, 2006 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
301 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
