Question about Toshiba Satellite Pro L300-EZ1004X Notebook
Got a l300 with vista original install and wont load windows up start screen comes up alllows access to bios etc but otherwise nothing
    Sergeant:
    Champion:
  • 236 Answers
Look in your bios for your hard drive. Is it showing up?
Posted on Mar 19, 2011
Installed wrong update bios for Toshiba Satellite L300D
You may have killed your laptop. BIOS have little to do with an OS like Windows, Linux, etc. The display issue is the culprit. Using another computer go to Toshiba website a get the current BIOS for your laptop. Are you able to access the BIOS at all? (press Del during bootup? to enter the Config screen (looks like DOS)
Mar 25, 2013 | Toshiba Satellite L300D-ST3501 Notebook
Hi i have a Toshiba Satellite Pro L300 i have reformatted the hard drive and am trying to instal windows xp Professional Genuine CD. I can access bios utility no problem and i start install for winxp it...
This because you dont have AHCI drivers required for Win XP and you set in BIOS either sata controller or ide controller to an AHCI. You must set to native IDE or anything else like that.
If you wish set an AHCI driver you must press F6 during starting windows XP setup. And put the drivers (get it here) to floppy disk, it will prompted to install required drivers..
Another way to install driver without floppy disk you must inject the driver to windows XP installation CD...
P.S : you cant put the drivers onto floppy, because it wont be read by Windows XP setup..
Aug 08, 2011 | Toshiba Satellite Pro L300 Notebook
Everytime i switch my toshiba l300 laptop on just goes to windows is loading files then i get bluey grey screen with system recovery box saying installed program cannot start turn off im running windows...
Download "Hiren's Boot cd".Burn the ISO images in a disc.Set your BIOS to boot using that disc.Select Mini windows XP.There you can have all the repairs tools pre-loaded.If none of the tools able to fix then you can always backup your important files and doa new re-installed.
Here is the link of lastest Hiren's Boot cd
http://d2.hirensbootcd.net/Hirens.BootCD.10.1.zip
You try to remove all the program during startup using that disk with "msconfig" command.
Let me know if it work out for you.
Dec 27, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba laptop satellite L300 Booting Problem
try the recovery wizard,also try pulling the hard drive,and ram,and bios battery if you can get to it,looks like watch battery on motherboard.or green plastic pack with two wire plug on main board,take the panels off on the bottom,if your lucky you will see it,otherwise have to dissamble to get to it.if you find it unplug for a couple hours,with main battery out and ac unplugged,should reset the bios to factory default ,might help ,do you have xp or vista?if your bios battery is the watch battery style be very carefull removeing it the holder will break off the motherboard easily,,if none of that works post a reply and ill give you some more options
Sep 10, 2009 | Toshiba Satellite Pro L300 Notebook
No display/monitor problem? When I turn on my Toshiba Satellite pro L300, I can see the Toshiba logo, bios menu, windows loading logo etc, then when it loads my desktop, nothing! No display, no graphics...
When you press power button press F8 key then enter in enable vga mode.
Then go to display proeprty and set screen rsolution to 1024*768 then apply.
Then check.
Aug 20, 2009 | Toshiba Satellite Pro L300 Notebook
My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
May 08, 2009 | Toshiba Satellite Pro L300 Notebook
My computer wont boot past Ai lifestyle screen(initial screen)
Boot from windows CD and after all drivers are loaded it will ask you what you want to do
"Install, repair etc" choose Install and then press the R key for repair and follow instructions from there
Feb 02, 2009 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Access IBM Button does nothing-- need it to start my comp up
The Access IBM button is F11. This lets you boot the recovery partition. It is possible the previous owner removed the recovery partition to regain the hard disk space it uses.
If the recovery partition is gone, you can order the recovery disks from IBM/Lenovo.
Also, make sure you have the BIOS boot sequence in the correct order.. the primary boot device should be the cd-rom for installing the Vista disk. It is usually F8 on startup to load the BIOS.
Make sure the Vista disk is in the drive when you startup the install.
Here's a link to all the Thinkpad R50e drivers you'll need to get it fully working in Vista:
http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html
If you have just formatted, have you let the Vista disk finish the installation? Just a thought..
Good Luck!
Chris (ziraffa)
Dec 29, 2008 | IBM ThinkPad R50e Notebook
Failed vista uninstall
do install the vista only, coz xp could not recognize the sata hd, it gives the blue screen error, if u want to install xp otherwise, install sata divers from the supplied disk with computer.
Nov 21, 2008 | Acer Aspire 5920-6727 Notebook
Toshiba Satellite Pro L300-EZ1004X Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
