Question about Kenmore 77082 Gas Dryer
Turn dryer on gas starts stay on for 20 second gas turns off 3or4 minute does i again ?
    President:
  • 3,074 Answers
This should help as it sounds like it may be the coils:
http://www.applianceaid.com/gas_dryer.html#noheat
Posted on Mar 19, 2011
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Heats for only 10 minutes the will not heat again
Your ignitor is going bad , Yes it sounds crazy, but this tip will explain further..
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Maytag SDG4606A Gas Dryer
How to prime intake, car was ran completely out of gas.
turn key to run position for 3or4 seconds and off for 3 or 4 seconds , do this about three times and it should prime and start , may run ugly for a few minutes after starting
Nov 25, 2009 | 1986 Nissan 300ZX
Maytag DG 412 won't stay lit
If the dryer can be restarted within 1 minute and it starts again it's not likely the coils. It may be poor air flow causing the safety thermostat on the flame tunnel going off as a warning. If it takes several minutes off to make it start again, it's likely the coils. When they cool down the broken coil contracts and the broken ends come back together (you can't see this). The coil kit number is 12001348 for the DG412.
Be careful not to break the ignitor when you service these...it is VERY prone to breakage. Turn off gas and electricity before servicing.
Aug 23, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Kenmore Dryer works for about 20 MINUTES, not seconds
SD, doesn't sound like the same problem. Yours sounds more the like motor kicking out on overload and when it cools down you are able to start it again. The thermal fuse and high limit TCO are non resettable so you can rule them out. You are going to have to check some things out. Make sure the rollers and pulley are not binding. The blower wheel is not binding. These things will cause a drag on the drum and put a heavy load on the motor. Catriver...post back
Feb 12, 2007 | Kenmore 64902 Electric Dryer
Kenmore 77082 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
