Question about Jura Capresso Impressa E9 Espresso Machine & Coffee Maker
Jura Capressa E9 Leaking
Coffee is leaking between the two spouts in my Jura Capresso E9.
Most likely the 2 spouts have become plugged with crud. Use a toothpick while the machine is dispensing coffee. Stick the toothpick up in each little nozzle and move it around it might take several cups to get this done. I removed the top cover on mine and just poored water in where the coffee normally goes. It is just a gravity feed system. Don't poor too fast and move the toothpick around until the blockage is cleared. Helps to have 2 people for this. Also, once you get it cleared, try the finest grind setting. Mine was set on the coarsest setting and I think that was making making the blockage more likley. I dont think the cracked spout is common though. My machine has made over 8100 cups and is going on 7 years. No cracks are visible in mine.
Posted on Apr 07, 2013
    Problem Solver:
  • 14 Answers
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
Posted on Aug 03, 2008
Leaking steam valve
Jura are a top brand and offer service and repair on their machines. Ask your local Jura dealer for a repair estimate.
Dec 20, 2013 | Jura Capresso Impressa E9 Espresso Machine...
Jura capresso e9 water not coming through spout
Use a pin or a needle on the spout to clean the nozzle head. Most of the time this is due to useing to fine a grind in the machine. You may have to clean the head this way more then one time to get it to start working again properly.If you have any further questions message me back.
Thank you
Rick
Nov 29, 2011 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capressa -Tray will not go in, looks like something from above protruding down in the back so that the tray sticks out 1/2 inch (so machine does not work)
I had the same issue. Had to send mine in for repair. Cost $235.00. Nothing I did would fix the issue. They said there was a major blockage. They cleaned it and sent it back. They also fixed my issue with water leaking from the frother.
Nov 08, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
My jura en9 pour spout clogged. How do I disassemble to clean out blockage? It is pour very slow and coffee is leaking out the sides of the spout.
Hi Eric
Can you get a pipe cleaner up the spout and clean?
Otherwise.... Take some photos and start unclipping & unscrewing
Thats how I replaced the Element in mine.
Check YouTube
Nov 08, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
One spout is very slow with leaking
The spout is only a plastic with two holes, if the one is only leaking while the other is running corectly then you only need to clean it with hot water and a small brush the hole and the groove. the spoot can easily removed, or even emese it in a pot with hot water for 20 minutes then flash only water.
Jan 05, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
I have a Jura-Capressa S9 that is leaking near the water intake. How do you open one of these to check it. They want $250 (flat fee) to repair it.
I have fixed this problem..................there is a small attachment on the back (2 in fact). the inlet & out let of the boiler.
The start to leak for some silly reason. U need to replace this
Apr 04, 2008 | Jura Capresso Impressa S90 Espresso...
Jura Capresso Impressa E9 Espresso Machine & Coffee Maker Logo
911 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
