Question about Sta Rite Mod Media 300 Sq Ft Cartridge Filter and 1hp Pump System
I changed my cartridges and now the filter will not fill to the top? I have NO pressure on the gauge and no pressure on the relief valve?
  • 56 Answers
It sounds like the seal didn't seat properly. Try re-seating the seal by opening the unit as you did to change the cartridges and checking the main seal (noted as part number 23 on the diagram) The seal should feel smooth and flexible not cracked or stiff. Re-seat as necessary and carefully close the unit. If you are still not getting any pressure try priming the unit as much as possible before starting.
Posted on Mar 19, 2011
Oil Pressure gauge is all of a sudden reading 80 psi! Was reading about 60 before. No change is the way truck runs. What is happening?
May be blockage in the system caused by either Dirt or heavy build up of carbon in system but more likely the filter is doing its job and his becoming blocked.
Change the oil when it is HOT and the filter and you should be OK
Aug 03, 2015 | 2005 GMC Sierra 2500HD 4WD
My inground pool filter guage is fairly new and registering 0 even though pool seems to be running fine
if you are sure water is circulating (check to see if water is being sucked into the skimmer suction port or you can open your air relief valve on top of your filter and water squirts out,) then you will know that all works, but if pressure gauge is "0", then replace your pressure gauge.
May 24, 2014 | Hayward SAND FILTER, PRO SERIES
We have a hayward xstream pool pump for our 18' above ground pool that my daughter got through make a wish last august. we cleaned the cartridge yesterday and when we replaced the cartridge it started...
Try taking the pool filters cartridge out and following these steps to make sure that it is installed properly.
1. Clean debris from bottom of filter tank.
2. Replace element evenly on the collector hub in bottom of the filter body.
3. Place lid evenly on filter body and turn Easy-Lok™ ring clockwise until the safety latches engage securely.
4. Close and secure drain plug (located at the base of filter body).
5. Open air relief valve (Turn lever to left).
6. Open valves (Optional suction & return valves).
7. Prime and start the pump.
8. Once air has escaped the filter and a steady stream of water is flowing from the air relief valve, close the air relief valve and note the pressure gauge reading.
Jul 15, 2010 | Hayward Pool Products Hayward Xstream...
Trany fluid coming out the relief valve on top of trany, i changed flid and filter
either its over filled or building too much pressure,which means you would have a blockage in the line or raidator!!!
Feb 28, 2010 | 2000 Oldsmobile Intrigue
Oil light is onin my 1999 daewoonubira i have topped up with oil and is still on now engine is making a noise
possible oil pump/pressure relief valve issue or pick up.
can remove pressure relief valve to clean/polish so it doesnt jam then check oil filter (how old?/blocked)
then recheck with oil pressure test gauge fitted to where oil pressure switch is to see what pressure pump puts out if any.
Aug 02, 2009 | 1999 Daewoo Nubira
COMPRESSOR RUNS, FILLS TANK, AND THEN LEAKS OFF ALL THE PRESSURE. WHAT IS GOING ON?
Is the air "leaking" from the pressure relief valve? If so it is either faulty or it is doing what is supposed to do. The pressure relief valve is there in case the pressure switch fails.The tank could blow up if the pressure switch fails, so the pressure relief valve is there as a secondary measure to insure the tank does not receive too much air pressure. Assuming your gauge is operating properly, watch the gauge to see if it reaches the maximum pressure (check your manual to find the maximum PSI) or if it goes over the maximum pressure. If it goes over the maximum pressure then replace the pressure switch. If it the motor stops at the maximum pressure, replace the pressure relief valve.
Jun 07, 2009 | Dewalt D55250 Factory Recondition Heavy -...
I have a Sta-Rite pool filter. In the start up procedure, you are supposed to bleed the air until a steady stream of water flows from the air release valve. Although I have confirmed that everything is...
Hi sstanl, Is your pump output or flow normal back to pool? if there is no water flowing through system you will get no expulsion of air or pressure reading on gauge. If pump is working then you probably have a clogged air release valve and maybe a clogged gauge. Just remove air relief assembly from filter top, remove gauge and clear any obstructions in parts. You should easily be able to blow air thru assy with gauge removed. Teflon tape the components and snug them back in their places. restart your pump and voila! air will come out when prime is established.
Apr 23, 2009 | Sta Rite Sta - Rite Mod Media 450 Sq Ft...
I have a ideal mini c24 cobi boiler and it isnt holding pressure the are no leaks inside the house it just seems to be releasing the water for the central heating from the blow off pipe outside so i keep...
So the boiler relief valve is leaking? What is the boiler pressure when the relief valve leaks? The relief valve will have a pressure rating on it. If the relief valve leaks when the pressure in the boiler is lower than the relief valve setting then its just a bad relief valve. If the relief valve is leaking when the boiler pressure gets above the relief valve pressure setting then the relief valve is doing its job and there is another problem. Several things can cause the boilers pressure to go higher than the relief valves setting. It could be a bad expansion tank or one that needs to be drained and re-charged. It could be a bad cold water fill valve that isn't shutting off and is over filling the system, rasing the pressure above the relief valve setting. If this boiler also does your domestic hot water, I have seen where the domestic hot waters heat exchanger has a hole in it and the domestic hot water is mixing with the boilers water and over pressuring the boiler.
Jan 13, 2018 | Heating & Cooling
Sta Rite Mod Media 300 Sq Ft Cartridge Filter and 1hp Pump System Logo
56 people viewed this question
Top Sta Rite Garden Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
