Question about HP PSC 1610 All-In-One InkJet Printer
Printer does not pull the paper from the tray even tho the document was successfully sent to the printer. I get an error message saying "out of paper" although there is paper in the tray. Why is this? How can I fix it?
    Sergeant:
    Champion:
  • 236 Answers
Sounds like you have a paper jam or a roller problem. Check the roller path and all doors and cavities for any sign of a paper jam
Posted on Mar 19, 2011
Printer notes "Error 6000". It is being used
Take a close look at the printer and the paper tray. The error usually means that the paper output tray is closed (or something is blocking it from opening). Remove the object blocking the paper tray and pull it fully open (including the extension). Then turn off the printer and turn it back on. The error can also occur when a book is being scanned that blocks the paper tray.
Some documentation on the Canon error messages for the MX860 is here: https://www.canon.ie/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/PIXMA_MX860.aspx?faqtcmuri=tcm:24-644260&page=1&type=faq .
I hope this helps.
Sep 11, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I have a Laser Class 710 and the error light keeps blinking. There is a message that says "incorrect paper size received in memory". How do I get rid of this?
Someone has probably sent you a fax on 8 1/2 x 14 inch (legal size) paper. Pull down the manual hand feed tray which is located above the regular paper cassettes and place some legal size paper in it. Hopefully the fax will be outputted and the message will go away. Good luck.
Jul 15, 2011 | Canon LaserCLASS Fax 710 Printer
I have a "printer error"
sometimes the paper can get stuck way at the back of the machine out of sight and it might be all crinkled up and stuck , the noise that you are hearing at start up is probably the rollers going through a pre-spin check that identifies problems like a paper jam etc you will have to remove any covers and expose as much of the internals of the machine as possible and open and trays and compartments that will allow you to use a torch to inspect the paper route and follow it path
Oct 28, 2017 | Epson Stylus Photo RX680 Printer
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
"Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Jan 11, 2011 | HP Office Equipment & Supplies
Printer says "error on paper tray". The paper is
Are you getting a specific error message or error code?
Jan 03, 2011 | Canon SELPHY CP740 InkJet Photo Printer
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Paper tray empty error message
Please click on the web link given below and perform the steps as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=1153494
This should fix the issue.
Have a great day!
Nov 23, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
