Question about Microsoft Windows NT Server 3.51 Full Version for PC
PC run windows NT server version 3.51, when booting, stuck: STOP, 0x0000007 inaccessible_boot_device - error and then dum Kernel how to solve problem
    Sergeant:
    Champion:
  • 236 Answers
Could be a memory issue
Posted on Mar 19, 2011
How to stop Windows 10 from automatically restarting after idle for around 5-15 minutes.
The kernel power event ID 41 error occurs when the computer is shut down, or it restarts unexpectedly. When a computer that is running Windows starts, a check is performed to determine whether the computer was shut down cleanly. If the computer was not shut down cleanly, a Kernel Power Event 41 message is generated.
Before we proceed with the troubleshooting steps, please answer the questions given below.
a)Do you remember making any changes prior to this issue?
b)Did you check if all the drivers are up to date?
Let us follow the methods given below.
Method 1: Run System maintenance troubleshooter.
Follow these steps:
a) Press Windows key + W on the keyboard
b) Type Troubleshooter then click on Settings under the Search field
c) In Settings click on Find and Fix Problems
d) Click on System and security
e) Click System maintenance follow the prompts from there.
Method 2: Try booting the computer in safe mode and perform a clean boot.
Step 1: Perform Safe Mode
Click the link and follow the steps "Windows Startup Settings (including safe mode)"
http://windows.microsoft.com/en-US/windows-8/windows-startup-settings-including-safe-mode
Check if you face the same issue in safe mode. If the issue doesn't persists in safe mode, the place the computer in clean boot and check.
Step 2: Perform Clean Boot.
To help troubleshoot error messages and other issues, you can start Windows 8 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
http://support.microsoft.com/kb/929135
Important: Reset the computer to start as usual.
Note: After you have finished troubleshooting, follow these steps to boot to normal startup.
a) Press the 'Windows + R' key on the keyboard.
b) In the 'Run' windows type 'MSCONFIG' and click 'Ok'.
c) On the 'General' tab, click the 'Normal Startup' option, and then click 'OK'.
d) When you are prompted to restart the computer, click 'Restart'.
If the issue persists, I would suggest you to perform a system restore and check if it helps.
Method 3: Perform a system restore.
Refer to the link given below and follow the instructions for system restore.
How to restore, refresh, or reset your PC
http://windows.microsoft.com/en-US/windows-8/restore-refresh-reset-pc
Also refer to the article given below.
Windows Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows 8, Windows Server 2012, Windows 7, or Windows Server 2008 R2
http://support.microsoft.com/kb/2028504
hope this helps
Jan 13, 2016 | Computers & Internet
How do you run CHKDSK /F with the blue screen stop error on my desktop?
You MUST have a boot device like CD, DVD, or USB. Use the install disc to access command prompt, by choosing the repair option. You could also download and burn a boot CD like Hirens.
The other option is to remove the drive and attach it as a slave or USB to another computer.
Oct 15, 2012 | Dell Computers & Internet
Resolve Error Code: C7 on SuperMicro Server
First check the OS compatibility for you motherboard here:
http://www.supermicro.com/support/faqs/os.cfm
Then, if compatible, check the IDE/SATA setting. Change the hard drive controller settings from IDE to AHCI or vice versa to see if the OS kernel panics on boot. If that does not work, please reply with your OS version and motherboard model.
Apr 12, 2012 | SuperMicro Computers & Internet
When i am trying to instaling win xp .getting a error message like stop 0x00000007B in a blue screen
hello Shameeralipk,
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
thansk.
Sep 06, 2011 | Acer Extensa 4230 Notebook
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
What is NTLDR error sir?
NTLDR (abbreviation of NT Loader) is the boot loader for all releases of Microsoft's Windows NT operating system up to and including Windows XP and Windows Server 2003. NTLDR is typically run from the primary hard disk drive, but it can also run from portable storage devices such as a CD-ROM, USB flash drive, or floppy disk. NTLDR can also load a non NT-based operating system given the appropriate boot sector in a file.
NTLDR requires, at the minimum, the following two files to be on the system volume:
  • NTLDR, which contains the main Boot loader itself
  • boot.ini, which contains configuration options for a boot menu.
This error means that NTLDR is missing somehow from your computer,hard disk problem,virus.etc
You can go to that page and follow the instructions exacty as he says and your problem will gone:)
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 12, 2010 | Abit KW7 Motherboard
IBM T20,inaccessible boot device
The Innaccessable Boot Device message means one of 2 things:
1: your hard drive has died - not much here, must replace drive.
2: The master boot record has become corrupt. Without any media, this will be hard to fix. You will need to boot to the Windows CD and either run the recovery console or perform a windows repair to fix this issue.
Jun 23, 2009 | IBM ThinkPad T20 2647 Notebook
Screen has stop inaccessiable boot device on it
If you are running windows, Insert your windows cd and set computer to start from cd. When prompted to, hit a key to boot from CD. Let Windows start the install (relax it is not really installing anything) when it gets to the prompt tell it you want to Repair an existing installation. Then pick the prompt that gets you the recovery console. When you get to the prompt type CHKDSK /R and let it run. Sometimes this can take an hour or more depending on the size of your drive. Do not get worried if the percentages complete go backwards, like from 70% back to 50%. Sometimes it will go back and fix files. Hopefully you will not get the error that there are unrecoverable errors. This has worked for me on about 90% of the hard drives that I received the inaccessible boot device.
Mar 10, 2009 | Dell Latitude D600 Notebook
Installing LaCie Mobile USB disk killed my Windows 2000 server
First, remove the usb disk, then when the computer boots up, press F8 continuously. Run the Safe Mode and try to uninstall the usb software and driver.
Jan 13, 2009 | LaCie 160GB Mobile Disk USB2.0 160 GB Hard...
Inaccessible boot device
hi,
Your boot setup has been corrupted. so I think you should reinstall the Operating system and choose the repair option..
Please get back to me and let me know whts up...
Jan 13, 2008 | Toshiba Satellite Pro 4600 Notebook
Microsoft Windows NT Server 3.51 Full Version for PC   Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
