Question about Maax Home
How do i remove the metal drain plug in order to clean the drain?
  • 17,970 Answers
Its possible that you find this answer amd graphics in maax.com/Upload/guides/fr/000_10050073_0305
Hope helps; keep us updated.
Posted on Mar 19, 2011
How can i fix striped drain plug in a 1998 civic d16y8
Hondas are notorious for stripped oil drain threads if you over-tighten them. Remove the drain plug and take it to an Auto Parts store and have them check the size in mm and then tell them to check the pitch. Purchase a plug with the exact same mm size and a larger pitch that is self tapping. Oil-Tite makes them. Use thread cutting oil and slowly go in and out until the threads are all cut. Clean the threads out and it should not leak. If it does use a fiber gasket and it will seal. If the threads inside the pan are not stripped and the drain plug itself has the stripped threads you can buy a replacement at almost any parts store. Another option is to use just buy a larger drain plug and the use a tap & die to cut new threads in the il pan that match the new drain plug you bought.
Mar 30, 2011 | 1998 Honda Civic
I need to change my oil
Actually, your oil filter is a little harder to do than this. The oil filter is not a traditional American type. You will find a metal skid plate or shroud underneath the car that will have to come off first. The filter is one of the paper cartridge types where you remove this metal cylinder, discard the old paper cartridge, and put the new paper cartridge in the metal cylinder and reattach the metal cylinder. I have an ES 350 and its not as easy as the other responder suggested.
Apr 06, 2010 | 2007 Lexus ES 350
Ok now that i know what i drained and it was the front gear axle oil and i temporarily used fits in tight glue because i stripped the inside groove where the drain screw goes and i stopped it for now ,i...
I worked at a jiffy lube for 7 1/2 years and have seen this alot. You have to put in what they call a helicoil. they are easy to use and can be gotten at www.helicoil.in ok hope this helps.
Oct 11, 2009 | 2001 Chevrolet S-10
Sounds like change grinding in spin cycle
This machine is prone to getting stuff down into drain pump. Pull unit away from wall, disconnect plug, hoses etc... Pull back steel panel of of rear of machine, facing rear of machine, drain pump on lower left, rinse pump on lower right, take needle nose pliers or spring pliers and remove hose to tub and drain pipe hose, tilt machine forward, take 5/16 nut driver and remove three screws holding pump, drop pump down, replace pump. Install in reverse order. Then, remove center nut in center of tub, pull center spinner out, then lift top to machine, remove inner tub and clean out metal, money or other stuff from bottom of outer tub, reinstall in reverse order.Once money has gotten into pump it can damage it, so replace it even though it looks good.
Oct 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
1997 Mercedes Benz C280 - oil change
hello,sorry,i just read your comments,better to remove your sump guard,(be careful),to see the oil drain plug,
Apr 21, 2009 | 1994 Mercedes-Benz C-Class
Remove the sheet metal panel from Whirlpool refridge
the rear panel is not removable. you need to clean the drain from inside the freezer compartment.
  • 1 remove food from freezer
  • 2 remove shelving and icemaker if equipped
  • 3 remover rear access cover in freezer usually 2 or 3 screw
  • 4 clean ice out from underneath the coil you will uncover the drain hole
  • 5 force hot water thru drain hole i use a turkey baster or large syringe
  • 6 reassemble in reverse order.
if you have any further questions please ask here and I'll be glad to assist any way I can. thanks Peyton
Mar 05, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Need to remove the big piece of sheet metal on whirpool refridg
Clogged drain
there is plastic plug that is used to stop the drain, when you pull the handle.
seems like the chain is broken off the the drain plug. the drain plug is one way plug.
the only suggestion I have is to open the backwall or the ceiling to get to the drain pipe. then you have to open the drain in order to fix this problem.
there is no easy fix, since you can't get to the plug that is in the drain, and the more you pull, the tighter it gets.
I don't suggest try to push the plug down, it may clogged the drain somewhere else.
Jan 01, 2009 | Eljer Arlington Non-Jetted Acrylic Bath...
Maytag Dishwasher won't drain
on all dishwasher think of them as a simple gutter system. the water only has one drain. At the bottom, if the pump can't pump out the water, its simply a bad pump or a clogged drain hose. Food particle can clog the "drain screen", use a good quality shop vac, clean 'drain screen', remove drain hose and clean thoroughly. If the hose goes into your drain pipe, remove that and clean that really good with snake it its metal or a strong 1/2 zip tie if its plastic.
Nov 30, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Changing engune oil
Before draining the engine oil, you'll want to unscrew the oil filler cap (it's usually made of black plastic, with a raised twist tab.) Doing so will allow the oil to drain more quickly. If the cap is hard to reach or tightly screwed on, you might want to use needle-nose pliers.Place a pan or bucket under the engine and use a socket wrench to remove the drain plug, which is located on the underside of the oil pan. Be careful during the last few turns, as the oil-- which might be hot-- will start to spill out. IMPORTANT NOTE: Be sure to properly dispose of used oil at a qualified hazardous waste disposal facility. Dumping used oil is both illegal and harmful to the environment. The crush washer is an aluminum or copper disc designed to deform under pressure, which helps seal the oil drain plug. This part must be replaced after each oil change, and is seen here being separated from the drain plug. The tip of the drain plug is usually magnetic, in order to attract slivers of metal shed by the engine. While larger pieces are typically found during an engine's break-in period, don't be alarmed when smaller pieces routinely end up stuck onto the edge of the drain plug; just wipe them off with a clean rag. While the oil continues to drain, unscrew the oil filter using a filter removal tool, which reaches around what might be a tightly screwed in filter. Once the filter is off, make sure the filter's O-ring (a band of rubber that fits on the tip to ensure a secure seal) came off with the filter. In order to remove larger particulates, unscrew and remove the plastic mesh filter from the side of the engine case. First, wipe the mesh off with a clean rag so no particles remain. Then, if possible, blow smaller particles off with compressed air. While the drain plug, mesh filter, and oil filter holes on the engine are exposed, wipe them all down with a clean rag to remove any accumulated sludge, in order to ensure a tight seal. Every new oil filter comes with an O-ring; ensure it is seated snugly in the filter and spread a dab of motor oil around its top surface in order to ensure a tight seal. Then, using your hand, screw the new filter into the engine case. Be sure NOT to use a tool for this part; it's easy to over-tighten the filter and damage the O-ring when using a tool. Once the old oil is completely drained, which should take at least several minutes, use a clean rag to wipe down the drain hole and the mesh filter hole. Screw the oil drain plug (with a new aluminum crush washer) and the plastic mesh filter back into the case. Use the owner's manual (or markings on the engine) to find out the engine's oil capacity, fill it up with that amount-- minus about one half quart-- by placing a funnel into the oil filler hole. Screw in the oil filler cap and start up the engine. Let the engine idle for about a minute, then shut it off. After the engine has idled for about a minute, shut it off and wait another minute or so for the new oil to settle from the cylinder heads into the crankcase. Make sure the bike is perfectly level; if there is a rear stand attached to the bike, remove it so it rests flat on the ground. If the bike doesn't have a center stand, lift it off its kickstand so it sits up perfectly straight. Check the oil window on the side of the crankcase: if the oil is below the center line, top it off until it's perfectly centered. If it's already at the center, voila-- you've just successfully changed your oil!
Nov 20, 2008 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
Home Logo
187 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
