Question about Garden
How to remove the rear wheels on an Atco 12/36 lawn tractor, after removing the circlip is a hub puller required?,
  • 376 Answers
SOURCE: how to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
Posted on May 15, 2009
  • 57 Answers
SOURCE: I was mowing lawn and stopped to remove debris
Check the drive belt.
Posted on May 18, 2009
panilling9
  • 284 Answers
SOURCE: I have a OLD Craftsman lawn tractor 36'' Drive belt diagram ?
go to sears.com click on parts and enter your mod#
Posted on May 26, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
  • 67 Answers
SOURCE: wheel rear wheel removal on a toro riding mower
take the bolt out of the center or the e clip off and the wheel should slide off but dont loose the key
Posted on Sep 01, 2009
How to remove axle from front of 1998 windstar
  1. Raise and support the vehicle safely.
  2. Remove the front wheels.
  3. Insert a steel rod into the brake rotor to prevent the rotor from turning and loosen the axle wheel hub nut. Discard the nut.
  4. Remove the ball joint-to-front wheel knuckle retaining nut. Drive the bolt out of the front wheel knuckle using a punch and hammer.
  5. Remove the front brake anti-lock sensor and position it out of the way.
  6. Separate the ball joint from the front wheel knuckle using a prybar. Position the end of the prybar outside of the bushing pocket to avoid damage to the bushing.
Use care to prevent damage to the front wheel driveshaft joint boot.
  1. Remove the stabilizer bar link at the front stabilizer bar.
Make sure the CV-joint puller does not contact the transaxle shaft speed sensor. Damage to the sensor will result.
  1. Install a CV-Joint Puller (T86P-3514-A1) or equivalent between the inboard CV-joint and the transaxle case.
  2. Install a CV-Joint Extension (T86P-3514-A2) or equivalent into the puller and hand-tighten.
  3. Using an impact slide hammer, remove the driveshaft from the transaxle.
Do not allow the front wheel driveshaft and joint to hang unsupported. Damage to the front wheel driveshaft joint may result. Do not wrap wire around the front wheel driveshaft joint boot. Damage to the boot may result.
  1. Support the end of the driveshaft and joint assembly by suspending it from the chassis using a length of wire.
Never use a hammer to separate the outboard front wheel driveshaft joint from the wheel hub. Damage to the outboard front wheel driveshaft joint threads and internal components may result.
  1. Separate the outboard front wheel driveshaft joint from the wheel hub using a Front Hub Remover/Replacer (T81P-1104-C) or equivalent. Make sure the hub remover adapter is fully threaded onto the hub stud.
Do not move the vehicle without the outboard CV-joint properly installed, as damage to the bearing may occur.
  1. Remove the front wheel driveshaft and joint assembly from the vehicle.
To install:
Do not reuse the retainer circlip. A new circlip must be installed each time the inboard CV-joint stub shaft is installed into the transaxle differential.
  1. Install a new retainer circlip on the inboard CV-joint stub shaft by starting one end in the groove and working the retainer circlip over the inboard shaft housing end and into the groove. This will avoid overexpanding the circlip.
A non-metallic mallet may be used to aid in seating the retainer circlip into the differential side gear groove. If a mallet is necessary, tap only on the outboard CV-joint stub shaft.
  1. Carefully align the splines of the inboard CV-joint stub shaft housing with the splines in the differential. Exerting some force, push the inboard CV-joint stub shaft housing into the differential until the retainer circlip is felt to seat in the differential side gear. Use care to prevent damage to the inboard CV-joint stub shaft and transaxle seal.
  2. Carefully align the splines of the outboard front wheel driveshaft joint with the splines in the wheel hub, and push the shaft into the wheel hub as far as possible.
  3. Temporarily fasten the front disc brake rotor to the wheel hub with washers and two lug nuts. Insert a steel rod into the front disc brake rotor and rotate clockwise to contact the front wheel knuckle, to prevent the front disc brake rotor from turning during front wheel driveshaft and joint installation.
A new front axle wheel hub retaining nut must be installed.
  1. Manually thread the front axle wheel hub retaining nut onto the outboard CV-joint stub shaft housing as far as possible.
A new bolt and nut must be used to connect the front suspension arm to the knuckle.
  1. Connect the front suspension lower arm to the front wheel knuckle. Tighten the nut and bolt to 40-55 ft. lbs. (54-74 Nm).
  2. Install the front brake anti-lock sensor.
  3. Connect the front stabilizer bar link and tighten to 35-45 ft. lbs. (47-65 Nm).
Do not use power or impact tools to tighten the hub nut.
  1. Tighten the front axle wheel hub retaining nut to 157-212 ft. lbs. (213-287 Nm).
  2. Install the front wheels and lower the vehicle.
  3. Using the recommended type of fluid, fill the transaxle to the proper level.
Jul 07, 2014 | 1998 Ford Windstar
Front wheel baring
Strip out front hub carrier,remove hub unit {a puller will be needed for this operation.There is a circlip holding the bearing in this needs to be removed. A press will be needed to remove and replace the bearing assembly. reverse strip down operation...Good-luck...
Jan 04, 2013 | 1994 Honda Civic
Mtd removing rear wheels from axel
Be very carefull, if you pull the wheels hard enough the half shaft will pop the circlip on the inside of the gearbox and come away with the wheel, this will then require a gearbox strip down, leave it soaking in penetrating oil and try again.
Jul 11, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
How do you pull hub off & change axil seal on cub cadet zero turn mower
Sound its rusted to axle. After remove e-clip from axle use WD-40 on both sides of hub. There small key goes in hub to keep wheel from turning on axle. The WD-40 should work. I've use a hammer on sides of hub not the tire. There spilt bushing on inside of hub, you need break loose. Back and forth works most of time.
Mar 05, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
I have a roper riding mower that needs a new rear tire, the wheel has no lug nuts, is there some kind of trick to release the wheel?
The wheels are not designed for easy removal. You have to pop off the hub cap, remove a retaining ring (which is easier with a special tool), and then pull off the wheel (which may require a special puller tool). So don't do it. Jack up the tractor and you can remove and replace a tire on the rim without taking the wheel off.
Good luck! If this is helpful, please rate my answer, thanks!
Jun 10, 2010 | Garden
Do you have a solution?
did you remove the clevis pin and clip (unless someone put a nut and bolt instead)..good luck
Apr 12, 2010 | Craftsman Rear Mount Tiller
How do i change front wheel bearing on a ford focus st2
SECTION 204-01: Front Suspension 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/18/2003 Wheel Bearing
Special Tool(s) 15064.jpg Installer, Wheel Hub Bearing Cup
204-023 (T73T-1217-A) 21171.jpg Remover/Installer, Bushing
204-180 (T93P-5493-A) 15064.jpg Installer, Drive Pinion Bearing Cup
205-140 (T80T-4000-F) 205153.jpg Adapter for 303-224 (Handle)
205-153 (T80T-4000-W) d84l1123a.jpg Puller, Bearing
205-D064 (D84L-1123-A) 21217.jpg Installer, Wheel Speed Sensor Ring
206-054 (T93P-20202-A) Removal
  1. Remove the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
  1. NOTE: When removing the hub from the wheel knuckle the bearing will be destroyed. The bearing inner ring will be on the hub and the bearing outer ring will be in the wheel knuckle.
    Using the special tools, remove the wheel hub from the wheel knuckle.
  1. ani_caut.gif CAUTION: The special tools must be used to prevent damage to the hub. If the hub is damaged a new hub must be installed.
    ani_caut.gif CAUTION: Do not use heat to remove the bearing inner ring.
    Using the special tools, remove the bearing inner ring from the wheel hub.
  1. Remove the circlip from the wheel knuckle.
  1. Install the old bearing inner ring.
    1. Install the bearing cage on to the bearing inner ring.
    1. Install the bearing cage and inner ring assembly to the wheel knuckle.
  1. Using the special tools, remove the bearing outer ring from the wheel knuckle.
Installation
ani_caut.gif CAUTION: Avoid any impact on the wheel speed sensor ring.
ani_caut.gif CAUTION: Make sure the wheel speed sensor ring is clean.
ani_caut.gif CAUTION: Avoid any contact between the wheel speed sensor ring and a magnetic surface.
  1. ani_caut.gif CAUTION: Make sure the wheel bearing is installed into the wheel knuckle with the wheel speed sensor ring, colored black, at the wheel speed sensor end of the wheel knuckle.
    Using the special tools, install the new wheel bearing to the wheel knuckle.
  1. NOTE: Make sure the circlip does not cover the wheel speed sensor.
    Install the circlip to the wheel knuckle.
  1. Using the special tools, install the wheel hub to the wheel knuckle.
  1. Install the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Apr 05, 2010 | 2000 Ford Focus
How to remove the rear wheel on a Kubota T1760 ride on mower
It is going to need to be lubricated and some patience. Use some PB blaster or Deep Creep penetrating oil. spray it a couple of times a day and let it soak. you may have to do this for several days. They do not put grease on the axle when they put them on.
Jan 14, 2010 | Garden
I have a husqvarna lawn tractor how do i take the
I don't know what model you have, but if the wheel has a single bolt in the center of the rim, the wheel is pressed onto the axle shaft and a puller is required to pull the rim off once the bolt is removed. For reinstalling, the bolt will press the rim back onto the shaft.
Hope this helps... Good luck!
Sep 22, 2009 | Garden
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
