Question about AT&T High Speed DSL Modem
What is the ip address for this modem so i can change filters
  • 49 Answers
If you are working on that modem, you should go to http://www.whatismyip.com/
It shows your IP.
Posted on Mar 19, 2011
Hpow u change ip adres
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
Aug 07, 2013 | Computers & Internet
How to change ip address
You can change only dynamic ip address by resetting the modem or switch off modem and switch on again.You cannot change static ip address.Static ip will not change even if you reset the modem or router or switch off the modem and switch on it.To check Ip address you can visit the site Ip-Details.com
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
Change ip address
If your IP address is static,you cannot change it.Static IP will not change even when you reset the modem.You have to contact your Internet Service provider(ISP) for changing static IP.If your IP address is dynamic,it will change whenever you reset the modem.If you want to check your IP address,visit Ip-details.com .
May 11, 2013 | Toshiba Satellite Computers & Internet
Why will it not connect to the internets IP address?
If you reset the modem and ip address will not change and remains same hence it is static ip address.If you reset the modem and the ip address change ,it is dynamic ip address.
You can get the Ip address from your internet service provider.you can check the ip address using the site Ip-details.com .
Jan 25, 2013 | RCA DCW615R Wireless/Cable Modem
How to change ip .. someone tell me
You cannot change the ip address by yourself.It is provided by your ISP.If you using static ip address it will not change even if you reset the modem or switch off and on...If your ip address is an Dynamic ip address you can change it easily by resetting the modem or switch off and switch on it...To check the ip address before and after changing you can visit the site Ip-details.com and check the ip and its details. you can also use Proxy server or Hide ip address software to change the ip address .
Nov 12, 2012 | Computers & Internet
Chaneg ip
There are two types of ip address available..One is static ip address it will not change forever...But another ip address is Dynamic ip address.It will change..If you need to change dynamic ip ,you can reset the modem it will assign new ip address for you...everytime you can reset the modem and get new ip address...It\'s possible only if you have dynamic ip...You can check whether your isp provided ip is static ip or dynamic ip by visiting the site IP-DETAILS.COM
Sep 15, 2012 | Computers & Internet
I have a Belkin N-Router and I was wondering how to connect it to my modem because the cable it has connects only to where the modem's ethernet cable is located when i just run my modem, and there is only...
plug the one ethernet cable from the modem into the router wan port . The modem will have an ip address note this and then change the ip address to one higher than the modem for the router's ip address and change the ip address in the router to make the gateway ip address the modem ip address.
Disable the DHCP server in the Router iIf the modem has an active DHCP server in the router.
Plug the rest of your network into the other router ethernet ports.
Feb 24, 2018 | Toshiba DOCSIS Cable PCX2500...
How did i change the ip
Your internet service provider only able to change your external ip address. The only way to change it own by using proxy sites or ip hide software's. Online proxy sites are simple and free of cost . But they worked for some periods only. So you can always check your ip is hide or not at Ip-Details.com
some free online proxy sites
hidemyass.com
hidemyip.com
boomtunnel.org
anonymous.org
Jul 15, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
AT&T High Speed DSL Modem Logo
122 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
