Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
On new maytag dishwashers what is the range of height adjustment? They are all listed at 34 1/2" high but there must be some adjustment plus or minus!
    President:
  • 1,273 Answers
Hi, W/D here.
They all have adjustable feet that can adjust the height up by about 2", or so. Check your manual.
The rear feet have a linkage to the front of the machine.
Best regards, --W/D--
Posted on Mar 19, 2011
What is the installation specifications on this particular model? Dimensions?
Patty,
Most dishwashers need an opening that is a minimum of 24" wide and 34" to 35" in height. Normally, you can adjust legs on the unit to adjust for the height you need, but you have no adjustment for the width. Hope this helps!
Mar 02, 2016 | Whirlpool 24 in. DU800CWD Built-in...
Which dishwashers are less than 830mm high, to fit under my work surface?
Peter,
830mm equals 32.68 inches. You will just have to look at the specs of any dishwasher that you are interested in and see if they will fit in less than that height. Most dishwashers that I have installed would fit between 32 and 34 inches in height. Hope this helps!
May 15, 2015 | Dishwashers
Avanti calls for a cabinet height of 34 1/2". However, the dishwasher is only 32 1/4" tall. What do you do to fill the gap of 2 inches at the top?
you don't fill the gap. There needs to be some clearance for the door to be able to swing open without contacting the underside of the counters. You can always decrease the gap a little by using the adjustable stands on the bottom of the unit. The unit will come with a kickplate that can adjust to multiple heights.
Apr 27, 2015 | Avanti Dishwashers
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
What are the demensions of my GE dishwasher Model# GSD2800D03?
Approximate Shipping Weight 100 lb Net Weight (lbs.) 90 lb Overall Height 34 in Height w/Legs Extended (in.) 35 Overall Depth 25 3/4 in Overall Width 24 in
Jul 23, 2011 | Maytag Dishwasher
I need the depth of the dishwasher I have the height at 34 1/2 and width at 23 7/8 Maytag MDBH969AWW
This may be too late for your needs, but, the assembled depth is 26 inches. 49.5 inches with the door open.
Jun 20, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
Need to replace this unit ASAP and am having issue finding one that will fit. My R.O. is exactly 34". The existing unit shown was OK because of the 33 - 1/2. Recommendations?
all dish wahers are the same height
the differance your seeing is that
is has been adjusted to fit your cabinet height
with the adjustable legs
all units can be raised by srewing down the legs
and back levelers
make sure when you do your cabinet measurements you take this into account
Oct 26, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Height for dishwasher is only 33.5 inches
we found a fridgidare dishwasher the had a range of 32.5-34 model number FDB2410HIC1 try it, it saved us from having to do alot of tile cutting
Jan 05, 2009 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
204 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
