Question about GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0
Inside unit has leak. would it be best to replace complete unit or just the leaking coil. .
    Genius:
  • 1,015 Answers
If it is a very small leak there are products made that can be put in the system through the suction sideYou will probably have to go to a hvac supply outlet to find them and if it is more than a tiny leak they won't work.
I would replace the entire unit as you will spend close to the same amount to cover all the extra labor to replace just the coil.Good luck and thank you.
Posted on Mar 19, 2011
My rudd uaka 037JAZ leaks, like to replace just AC and not coil and furnace motor. Replacement suggestion for this unit? Homeowener George
Hello, it depends where the unit is leaking from, if it is leaking from the condensing unit then you can just replace the condenser, however if it is leaking from the evaporator coil then you will need to replace the evaporater. As far as brand for replacement I like rheem equipment. The best thing to do is have a hvac technician come out and give you a estimate on a new AC and then you can make a decision.
Feb 21, 2011 | Ruud UAKA037 Air Conditioner
My samsung unit was leaking water from the inside unit and then it stopped working
Thanks for your detailed statement as stopped working after water leak.
Water leak due to
It's because of non-maintained air conditioner. Clean airfilter, indoor coil, blower wheel and also drain pan. Insulate freon pipelinesproperly and tightly. After that run the a/c. If still water dripping. Checkindoor f.motor speed. If less replace capacitor. If f.m. is o.k, check gaspressure. If less, there will be ice formation over the coil and water drippingwill be there when it melting. If short of gas, check for leak andrectify. (Unit stopped as coil sensor is activated while ice forming over coil)Thanks. Helpful?
Jan 26, 2011 | Heating & Cooling
The inside unit is leaking water
Water leaking in split unit common, due to air filter & evaporator coil dust blocked- Clean it.
Drain pan and drain hose dust blocked-clean it. And also due to less rpm of indoor motor, there will be forming ice over the coil result to water leaking while defrosting.Replace motor capacitor.
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
The plenum that houses my coils sweated repeatedly and the coils seemed to freeze. An agent told me that my unit was leaking at the fittings to the outside unit as well as the coils . The unit he used to...
Hello JBESTER Defrost the unit completely and see if the pressures are low.If more than half the charge/freon(3+)lbs has to be added you have a leak.Make sure the air filters are new as poor air flow can cause ice also.The sniffer I use beeps all the time BUT when near a leak goes crazy!The coil can leak after 6 yrs.You will always will need a recharge untill leak is resloved.
Aug 25, 2010 | Carrier 38CKC036 Air Conditioner
Inside 18000 btu has leak in coils
If you do not know where the leak is located there are several options however, since the leak is on the inside coil it may be nearly impossible to access the area to weld the leak shut. If the leakage isn't excessive there is a chemical out that you add to the low side of the unit and it circulates throughout the system and seals the leak. Remember that if the leak is excessive this will not work. Your local a/c company should have the name of the sealant made by a company out of Canada but an a/c tech will have to evailuate the system first to see if the sealant would be effective. Also, you can purchase the coil by itself from an a/c company and have it itstalled saving quite a bit of money rather than buying a complete system The cost of the coil byy itself is usually a 5th of the cost to replace the inside unit and can be done really quick. A/C companies do not tell you this due to the monies they make selling a complete unit. Good Luck on your repairs hope this helped
Dave
Oct 20, 2009 | Amcor Aire AMS241HX Split System Air...
Tube running from AC unit to the house is completely encased in ice. Does this mean the unit is bad ? Or, does this mean there is a freon leak in the tubing ? And, is it cheaper to replace to unit or try...
You either have a refrigerant leak or a dirty inside coil or a slow running inside blower motor.
Set the thermostat for heat and run it until all the ice is thawed. Then check the incoming air side of the coil for lint and dirt. Check the fan motor for proper speed. If you have service gauges your low side pressure should be approximately 68 psi. If lower you have a leak.
Jul 07, 2009 | Carrier 38CKC030 Air Conditioner
My system is running but not blowing cold air
It depends where the leak is. If its in the coils, you have to replace it. If the leak is easy to get to it would be cheaper just to fix it. So it all depends where the leak is. but 15 years is kind of old for a unit.
Jun 24, 2009 | Heating & Cooling
Coil blew up on outside unit, is it better to fix or replace whole unit?
Depends on where the coil is leaking. Also the age of the unit. If it is just a small leak a serviceman can repair it. You have to look at how much it will cost to repair, And the cost of new unit.. The new unit will be a 13 seer and may not match the inside coil. . Also some Companies are selling 10 year parts and labor warranties with new units. Look at the leak on your coil to see what caused the leak. Most of the time it a rubbed line or drier leaking. If you have to cut away fins. Buy another condensing unit. When you cut away the fins you loose heat conductivity. Higher head pressure could cause damage to unit. Rusty
Jun 03, 2009 | Weather King 10AJA6001AH Air Conditioner
Coil leaking freon on the inside unit. Estimate is $2,100!
If indeed your evaporator (indoor) coil is leaking, the best option IS replace it (it may not even BE repairable). If you live in the USA and your furnace is getting old, a new ultra high efficient SYSTEM that qualifies for the tax credit would probably be a better option (Obama will pay 30%).
May 09, 2009 | Carrier Heating & Cooling
GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0 Logo
48 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
