Question about Car Audio & Video
I just installed a new Boss Audio BV9555 340w 4 channel, 2din touch screen player into my 2002 ford mustang. I am having troubles keeping my amps powered on. My amps run off a seperate power source i have intalled in the back. i have Three JL Audio amps that used to work with the old deck, but now they dont stay on. They turn on for like 10 seconds with the green light on, then turn off with no lights on. then i cant get it to turn back on. but if you wait like 5 minutes or so it will turn back on and the same thing happens again. You have any idea what could be causing this or what i can do to fix this???
SOURCE: amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Posted on Feb 08, 2007
  • 11 Answers
SOURCE: KDF-E60A20 Going on and off by itself..no blinking lights
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
LVT7857
  • 116 Answers
SOURCE: Green light blinks slowly on my JL Audio 300/4 amp
Check your fuse at the battery. While AGU glass fuses "look" good, when you read the voltage AFTER the fuse, you can only be getting 5 volts or so. I can't tell you how many times I have seen this.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
hotratchet
  • 952 Answers
SOURCE: My Amp Keeps shutting off
You need to get an amp with higher wattage. Obviously, your amp cannot handle those two 10" monsters. hehe Nice Subs though :D
Posted on May 01, 2009
  • 150 Answers
SOURCE: jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Posted on May 12, 2009
My boss BV9976 dvd player touch screen is not working
It's possible that the Boss unit works with iPod and iPhone 3 and not the four. Does the unit state that it works with iPod/iPhone? Also, you may require a software upgrade
Mar 17, 2012 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
What would be the best way to wire 2 1800w 4 ohm boss compact speakers to the boss cx950 amp
As the amp cannot support a 2ohm load you have to hook each sub up to one channel on the sub and you can't run them in bridged mode.
Mar 09, 2012 | BOSS AUDIO SYSTEMS CX950 Car Amp
I have the Boss BV9996B player. Since I got it installed it keeps searching channels and won't stop!
check the installation of the tuner antenna.. set the tuning program from auto to manual settings...ty
Jun 21, 2011 | BOSS AUDIO SYSTEMS BV9996B Car Video...
I have a boss s120.5a 12" sub with 5 channel 3000
Check the power pack and the fuse to make sure the are working but if the are not okay then take the car audio amplifier to audio mechanic.
Jan 22, 2011 | Boss gt580 - GT580 1000W 2 Channel MOSFET...
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Boss bv7985
there should be a wire they wanted you to hook to the parking brake as a safety feature so you cant drive and watch tv. but you can just take that wire and ground it to your black ground wire on your radio that should give you your pic
Mar 09, 2009 | Boss AUDIO SYSTEMS BV7985 Car DVD Player
Dvd disk won't eject???
this is device do not play dvd-video, onli dvd-rom with maps for gps-navigation.
Apr 28, 2008 | Eclipse AVN5495 Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
