I have a HP Color LaserJet 3505n and just replaced the Cyan toner cartridge 3 days ago . . . but whenever I print anything, no blue shows up on the right side of the page. I don't see anything wrong with the cartridge (it was new, not recycled). The only thing I can think of is that I bought the cartridge last year in a package deal, and left it in the garage until 3 days ago when I needed it. Do you think that's the problem?
    Sergeant:
    Champion:
  • 236 Answers
That could very well be the problem especially if there were temperature varations in your garage
Posted on Mar 19, 2011
HP color laserjet cp2025 will not print. Help.
No.
Very few printers will print if they're out of toner, even if the colour toner is exhausted and the print job is only black. Replace the empty toner and if this is the only problem, the printer will continue printing.
Jan 20, 2015 | HP Laserjet Cp2025n Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
I have a HP Color LaserJet CP3505n and just replaced the Cyan toner . . . but whenever I print out anyting, there is no blue color on the right hand side. I did buy the toner last year in a package deal...
I don't like saying call the manufacturer, but in this case....
HP has an "out of the box" warranty when it comes to toners.
If you bought the toner 6 years ago, but took it out of the box 2 weeks ago, your warranty started 2 weeks ago.
Call 1-800-HP-Invent and they will of course want to troubleshoot with you, but it won't cost anything if you explain that you just installed the toner, it's new, and you are having this issue.
They should treat it as "accessory under warranty".
They'll either stumble upon what the defect in their cartridge was, or in all likelyhood they will simply replace it.
Mar 19, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
Hi there, need your kind help. My Hp laserjet 5550 has a missing colour problem. Cyan is missing in the print out, giving rise to to blue and green colours being absent in print-outs. Scanner is confirmed...
Cyan cartridge is OK, means that the display shows the level of toner in the cartridge, right? Then chip it is ok.
Try another cyan toner, the printer may be that it has broken the opening flap of the laser. Or check if the laser's flap cyan is blocked.
Nov 14, 2009 | HP LaserJet 5550 Printer
Cyan is offset about 3/16"
check the locking tabs on the cartridge, sounds like they are not locking down the cartridge.
Jul 31, 2009 | HP LaserJet 3600n Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
The red is not printing
At a guess you are using recycled toners? If the recycler has not worked out the refilling procedure properly, the problem you experienced with the exploding Cyan toner is common. It is possible in the act of blowing out the loose cyan toner your have used to much air pressure, possibly blowing toner into the laser beam units, or damaging the toner sensor unit for magenta.
A diagnostic inspection, by a technician would be suggested.
Cheers: DeJudge
Dec 30, 2008 | HP Color LaserJet 2600n Printer
Flashing Lights
From the User Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
If you don't have a User Guide click on the link below and save it for future reference.
2550n User Guide
If this solution has been helpful, please rate it. Thanks!
Jul 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
63 people viewed this question
k24674
jasbo
jasbo
