Question about Joal Volvo L70 Loader
I need a head for my volvo l70 engine its a tb45 engine
If a Volvo s40 throws its timing belt does it ruin the engine?
Only way to assess the damages is to remove the head and check
Aug 06, 2014 | 2000 Volvo S40
Need the head bolt torque specs for 2001 Volvo v70 to replace heads
need more info of the car, engin sice and is it petrol or diesel
Jul 24, 2014 | 2001 Volvo V70
How to change the head gasket on a volvo 00 S40?
are you sure its the head gasket? they can suffer with
condensation. mine suffers from this during cold
weather. if it does loose water likely to be that.
taking head off bit of a pain. you need to support
engine. remove auxcillary belt and timing belt some
wiring water pipes manifolds top engine cam shaft
head bolts
Jul 06, 2014 | 2000 Volvo S40
Can anyone give mer advice ?..i got 1995 volvo 960 2.5l engine..i need to replace head gasket.how to remove intake manifold clamps?..they are crimped...do i need to replace them too...does it need special...
To get a solution to this I would go to a volvo dealership and talk to a mechanic. Or I would go to a mechanic that specialises in volvo and talk to him. If you are still not happy get a repair manual (Haynes --Gregorys or original work shop manual.
Apr 03, 2013 | 1995 Volvo 960
My samsung digimax L70 lcd got broken and i need to get a new lcd for it. where could i find a new screen?
You could buy it from :-
http://cgi.ebay.com/LCD-Screen-Display-Parts-Samsung-Digimax-L70-L-70-/280389738500?pt=Digital_Camera_Accessories
Good Luck!!
Thanks!!
Aug 18, 2010 | Samsung Digimax L70 Digital Camera
Tran charge pump presure low. changed pump volvo loader L70C
Stopped up suction screen can cause this. Also pressure regulator.
Jun 16, 2009 | Plumbing
Head bolt torque specs and timing marcs for a 94 volvo 960 6cyl
you do 14 foot pounds then 45 foot pounds then a 120 degree turn.if aluminum heads are what you have
Oct 05, 2008 | 1992 Volvo 960
Joal Volvo L70 Loader Logo
55 people viewed this question
Top Joal Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Joal Toy Expert? Answer questions, earn points and help others
