Question about HP LaserJet 5L Printer
When I print either a word doc or excel I get nothing printed but only garbled language as 1 line sentence on the paper: Something like this: AQKM!SEU!QAGEQSOUECU=AUUOAQKM!SEU!SESOMUUIOO=711AQKM!
  • HP Master
  • 1,591 Answers
Your default printer is pointing to the wrong driver in Windows.
I can't give you step-by-step because you made no mention of what version of Windows you are running, but basically you need to go into the printers folder in control panel and make the HP 5L the default printer.
If the 5L IS the default printer, you need to remove and reinstall the driver.
If you don't have the CD the driver is available at HP.com or when you web update the print drivers (as in Windows 7 when you go to add the printer, do the web update, and it'll be in the printers list afterward).
Posted on Mar 19, 2011
  • 111 Answers
Is it printing like that only on Word and Excel? If not you better uninstall the printer driver and reinstall again.. sometimes installed drivers get mess up specialy if we have done some updates or installation in other software.
Thanks
Printer is printing with horizontal blank lines
you did not indicate machine or how you are printing.
1- printing from glass or doc feeder?
did you check the small scanning glass on left side?
usually if there is a dot (pen dot or similar) it will come out as a line on docs, this is because the paper is moving while scanning, so it now sees the dot a s a line. Line up the paper w the glass you should see where the problem is comong from.
Sep 06, 2012 | Office Equipment & Supplies
Printing only every other line in Word 2007 doc
Dear pony, it could be because you might have changed your print settings.
You can press CTRL+P to change settings
You might also select the text you want to print and print selected.
You can also format the text by going into formatting options of MS word.
This can be because you've put the number of copies to 2. Thats why its printing again. Change it to default and it should fix your problem
If that has helped you please press 'fixya'
Nov 30, 2007 | Microsoft Office Professional 2007 Full...
When printing lines are running through the sentences.I have a brother mfc440cn printer
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 09, 2009 | Brother MFC-440CN InkJet Printer
Won't Print, copy or scan
Take the cartridge back out and reinstall it just to be on the safe side. If that does not clear up the problem, there is a very strong possibility that you have a faulty cartridge that needs to be replaced (it can be faulty even if it is a new cartridge). - Graye
Nov 02, 2008 | HP PSC 1410 All-In-One InkJet Printer
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Printer prints just part of sentences
Heeheehee do I feel stupid I just checked the printer for the upteenth time and finally found the problem.
I had a piece of paper (sticky price tag paper ) on the ink track so that was what was causing my problem. It was covered in ink LOL.
Wanaka
May 06, 2008 | Lexmark X1240 All-In-One InkJet Printer
Printing Docs
This model does NOT support edge to edge printing.
You can have the document reduced to fit the sheet size in Excel.
Feb 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Ms word 2007 docs print every other line
This seems like a print driver problem. You may have to get an updated driver for your printer for Msoffice 2007.
Sean
Brother dcp 7020
I've seen a similar problem like that.
Turns out that the first page is not totally blank, take a VERY close look at the first page, is there a line line (hyphen) or a dot
( or something that looks like a period at the end of a sentence)
what happens is that no matter how small or insignificant it may be, it HAS to print out that doc.
or it is printing out a cover sheet, look in the manual and look to see if it has an option for cover sheets.
good luck
Oct 16, 2007 | Brother DCP-7020 All-In-One Laser Printer
HP LaserJet 5L Printer Logo
93 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
