Airtunes express setup
Need to know the IP address of the device and also how to get it access to our itunes wirelessly by getting the password into the device
    Problem Solver:
No, no solution and no response to my request for how to get a rebate on the TWO 14.99 payments I made - or to get someone who CAN help us with this. not happy about that.
Posted on Aug 04, 2008
Where can I get an I.p. address for my tablet . Im not sure what happened , I put it back to factory settings and after that there was no ip address. Please help?
What most likely happened is when you factory reset the device, the wireless setup that you use to connect to the Internet was reset as well. You need to go into the wireless setup area and look for networks to connect to. The one that you use regularly (assuming you are where you use the device), should be among those listed. You then tell the device to connect to the network. This is where the device will ask you for the network password if it is a secure network (and most are). Once you input the password, then the network router will assign an IP address to the device and connect it to the network. After that you can access the Internet normally. If you don't know or forgot the network password, someone in the household (or business) should be able to provide it so long as you are authorized to connect.
Dec 11, 2015 | Sungale Tablets & eReaders
I am using the airport express to play itunes through my stereo only. I unplugged the unit to move it to a more convenient place and now I cannot to get it to work. It was working well before. I...
From my reading at the Apple support web site, it appears that you may need to download the latest version of the Airport Utility in order to get around this issue.
Additionally, Apple has just recently come up with an update to the firmware for this device.
Try downloading the latest version of the Airport Utility (Mac or Windows) and see if that doesn't resolve the issue.
After installing the latest version of the Airport Utility, try to connect to the Airport Express. If that is successful with the new version, click the "Manual Setup" button to display the "Summary" page for the Airport Express.
Next to the entry for "Version:" there should be a button to press to upgrade the firmware to the latest version (7.5.2). Perform the upgrade by following the on screen directions.
After the upgrade, again attempt to connect to the Airport Express using the Airport Utility. This should work as expected.
Before attempting to use the AirTunes (recently renamed "AirPlay"), make sure that you have the latest version of iTunes installed.
Dec 27, 2010 | Apple AirPort Express Base Station with...
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Only one computer on my wireless network finds Airport Express. I have Airport utility installed on both of my laptops in my network, but only one of them finds the Airport Express? I can ping the...
Dial 1-800-204-4427 US Toll-free Number & Get the best assistance for Trusted Apple Technical support. We proffer an online Apple Technical Support assistance to the customers and fix their glitches in a professional manner. Read More... Apple Customer Support Number 1 800 204 4427
Jun 19, 2017 | Apple AirPort Express Base Station with...
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Cingular WAP settings
Hi..i am providing you with the WAP and other settings,but still if you need any help,then please contact Cingular at 866.CINGULAR(866-246-4852)
For CSD (Wireless Internet)
Function Setting
Settings Name: Cingular Wireless Internet
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
Dial-up Number: 14152441012
Gateway IP Address: 66.209.11.61
Authentication Type: Secure
Dial Type: ISDN (on network)
Analogue (off network)
Login Type: Automatic
User Name: WAP@CINGULAR.COM
(All upper case)
Password: CINGULAR1
(All upper case)
For GPRS (Wireless Internet Express)
Function Setting
Settings Name: Cingular Wireless Internet Express
APN: wap.cingular (lower case)
PDP_Type: IP
User Name: WAP@CINGULARGPRS.COM
(All upper case)
Password: CINGULAR1
(All upper case)
Now to set up MMS (Multimedia Services)
Homepage: http://mmsc.cingular.com
Gateway IP 1: 66.209.11.61
Port 1: 9201
Domain 1: (blank)
Service type 1: WAP
Gateway IP 2: (leave alone)
Port 2: 9201
Domain 2: (blank)
Service type 2: WAP
DNS 1: (leave alone)
DNS 2: (leave alone)
Timeout: 10 minutes
CSD No.1 14152441012
Username 1: WAP@CINGULAR.COM
password: CINGULAR1
Speed(bps): 9600
Line type 1: ISDN
CSD No.2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed(bps)2: 9600
Line type 2: ISDN
GPRS APN: wap@cingular
Username: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Good luck :-)
Apr 22, 2010 | Computers & Internet
How do I make my connection secure to the internet? I have linksys wireless-G 2.4 GHz broadband router. The router is all hooked up but I believe the current connection is unsecured.
When you connected, did it ask you for a password? If not then it's obviously unsecured. Here's how to fix that... i have the same router.
On XP... open internet explorer... in the address bar, type in: 192.168.1.1
On vista.... click start menu...click on network...right click on router and select properties. Next, click on the "Network Device" tab at top of the new window. You will then see "Device Webpage"... click on the ip address to the right of that underlined in blue. It should ask you for a password... if you haven't set one manually the user is admin and the password is also admin. I recommend changing that to a manual password ASAP. Ok, after logging in, now you have the router's set up page in your web browser.
To make it secure:
On the set up page you now have open... you have a few selections that act like tabs: Setup, Wireless, Security, Access Restrictions, etc... Click on Wireless. After clicking on that, you have some tabs underneath wireless you can click on now.
Those selections should be: Basic wireless settings, Wireless security, Wireless MAC Filter, etc... Click on Wireless Security. There you should see disabled on the first drop down. Pick a WEP, WPA or whatever you prefer. I personnally use WEP with 64bit 10 hex and for the password, i use a 10 digit number.
After you have set up your password and security, click save settings at the bottom. After it's done processing the save, you can close the web browser. You are good to go now.
By the way, I recommended changing your password to access the router's set up page. Make absolutely sure you save that username/password in a safe location. If you forget it, there is nothing linksys can do to help you. I know from experience unfortunately.
Hope all this helped... Good Luck
Jul 02, 2009 | Linksys Wireless-G WRT54G Router
Airtunes wireless itunes network password
Yes since you done have the passkey you will have to reset the router/modem and then set up a new passkey then you are all set. But refer to your manual or online manual to rest your modem/router.
Aug 02, 2008 | NetGear MR814 Wireless Router
WEP KEY
disabling WEP security is not a great idea, unless you plan on replacing it with WPA. As for your request, please open a Browser and enter 182.168.1.1 into your address bar and hit enter. I can't seem to recall exactly where the setting is, but you will come across it if you look through the router admin page. Hope this helps.
Dec 21, 2007 | Computers & Internet
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
