Question about Home
Toilet won't stop running. Flapper is fine, I raised the floater, every third flush it spills into the overflow. The slightest touch on the topmost piece of the assembly, and it stops.
  • 46 Answers
Raising the floater will raise the water level which means overflow and water will keep running.
You need to lower the float to stop the water at a lower level.
Posted on Mar 19, 2011
Our toilet systern is constantly running it won't shut down
Faulty flush valve or leaky flapper
Nov 30, 2017 | Home
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 | Home
Water wont stop running
Water is either running (1) into the overflow tube or (2) out to the toilet under the flapper at the bottom of the tank. If (1) lower the ball or float. Done differently depending on model. If (2) replace the flapper with new flapper designed for your model. (Note: Raise manually the float valve and if water still runs out the little tube that goes into the overflow tube then fill valve is defective. Replace it.)
Mar 24, 2013 | American Standard Home
Our toilet Kohler 4634AA will not flush. Changed the flapper, followed the directions, etc. but still won't.flush properly...runs runs runs.
If the tank is filling with water to the line level, and the flapper raises, and stays raised until tank is almost empty, when flushed then it must be a clogged line. Try a plunger (toilet snake) and/or call a plumber.
Sep 04, 2011 | Home
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
The water kept running after finished flushing and tank gets full. The floater is at a right height. Replaced the rubber flopper. I can see that the water is running into toilet bowl from small holes on...
Either you did not get the right flapper or you have a crack that is letting the water through even though the flapper is sealed...
Cracks can be very hard to identify, but if the flapper is sealing good then that's your problem...
heatman101
Aug 04, 2010 | Eljer Toilet Onepiece Canterbury ...
Water continue to drip just a little after fill valve stops
Check the little tube the goes from the fill valve into the overflow tube. You NEED to have a good arch in the tube to prevent back siphon from the tank. If that doesn't work then check to make sure the flush valve flapper is completely seated without any of its port showing. If you see the slightest amount of the flush port then you need to replace the flapper. AS well as make sure none of the chain is getting siphoned into the port preventing the flush valve flapper from completely seating.
Mar 20, 2010 | Toto Toilets ST784S 12 Sedona Beige...
My toilet runs! the flushing flapper is all brand new and it still runs after it flushes, not all the time, but about 75% of the time. If I wiggle the handle it will stop. It is a 40year American Standard.
More than likely the chain for the flapper is getting underneath the flapper. Shorten the chain length to avoid this. If that does not solve your problem then make sure the flapper is aligned properly with the hole. If it is off just the slightest it will not fully seal.
Jan 02, 2010 | American Standard 2860.334 Enfield Two...
Shortly after toilet flushes, you hear a tinkling sound for several seconds, as if water dripping inside. Sometimes also hear another sound like flushing even though toilet is done running,
Check the water level inside the tank to be sure the tank isn't overfilling and spilling into the overflow tube.
Also check the flapper valve (the rubber valve at the bottom of the tank that sits over the flush hole and is connected to the flush handle) to be sure it is holding and not leaking.
Make sure the handle chain that goes to the flapper valve isn't tangled up and holding the flapper valve partially open.
Dec 12, 2009 | Office Equipment & Supplies
Toilet keeps running even when manually lifting floater to max
check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Oct 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Home Logo
77 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
