Garden Logo
Posted on Mar 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. I bought a Makita cordless drill, model 8391D. Whilst drilling a pilot masonry hole it suddenly stopped. The battery had only just started to slow so I changed it anyway to a fully charged one and the drill was still dead? Someone has mentioned to change the brushes? Could this be the problem. The drill is only about ten months old. Any info appreciated.
Anonymous
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Mar 19, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1015
Questions
0
Helped
319824
Points
3041
I would try changing the brushes and use compressed air I would blow out all the dust and lint I could from around motor.
If this does not help I would return for guarntee replacement. Thank you.
Why does my Makita 6011D cordless drill not work when my charged battery in installed? The battery does work on my Makita saw so I know it is not the battery.
Look inside where the Battery terminals connect.
THey are flat metal springs inside the drills Battery hole.
Make sure the are not compressed down causing them not to touch the battery terminals of the battery.
ALso check the Brushes on the drills motor they may need replacing...
Selvol
I have a makita 8391d cordless drill The problem is that the drill runs incredibly slow even when both batteries are fully charged I have checked the voltage and both batteries are showing the correct...
You have to check the batteries with a new machine. If the new machine works ok then the rotor of the motor of the old machine is broken.
Jan 18, 2014 • Drills
4helpful
2answers
How do i remove the chuck from a Makita 8391D
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
How do i remove the drill bit from a Makita 8391d cordless drill
Put the clutch on a high number, put the reverse on, hold the chuck tightly, lightly press the triger. If it does not come undone, make the clutch tighter (loer number).
Jul 17, 2010 • Hand Tools
4helpful
8391D left out in the rain!
If the battery was connected you probably shorted out the battery. Shake all water out of drill and let dry. get a battery that was not in water, try this. If still won't work you will have to bring to repair shop. If you try and take it apart it may be hard to put back together.
May 02, 2010 • Drills
2answers
Makita 12v starts intermittingly
i would say its the switch!
but i would jump the motor directly to the battery bypassing the switch to be sure
1helpful
3answers
Makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Top Makita Garden Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Makita Garden Expert? Answer questions, earn points and help others
