Question about Microsoft Wireless Notebook Optical Mouse bx300008
I have the microsoft Model 1051 mouse receiver, I put in the usb port on my desktop tower and it does nothing anymore there seems to be loose around where in goes in for connection, is there anything i can do to get it to light back up, the mouse works fine when i put the battery into it, help me solve this problem, I really like the wireless connection .
I tried to open the receiver , and it fell down
after that it started working
Posted on Aug 26, 2012
  • 1,591 Answers
Well honestly, wireless mice are pretty cheap, but I can understand the attachment to this mouse as I gave one too.
First, try the dongle (usb stick) in another system.
If it works in another system, then the problem is with your computer, not the stick.
If not, I can't tell you how to crack the thing open without destroying it, so do so at your own riskm but you have to get the shell off the adapter and check the solder joints where the USB connector meets the circuit board and solder down .... Oh, I'd resolder all of them!
Good luck. and let me know how you make out with that!
Posted on Mar 19, 2011
What is a USB receiver?
If your computer is a laptop, most of (all) laptops comes with a built-in wireless adapter. And if it is working, you don't need one.
If you have a desktop (a tower casing, monitor, keyboard and mouse) setup, mostly they don't have built in wireless receiver. But if your desktop is custom built like mine, I have installed a wireless card in my desktop. But not really recommended. Since it sits in the desktop tower casing and if you need to get more signal and have to move around, you get furious because it is not mobile.
USB receiver or adapter can be extended via a USB extension cable (3 meter, 7 meter, 10 meter) and put it where the signal strength is high or remove it and use it on any other computer (laptop or desktop) with a USB port.
So, if your computer is not equipped with a wireless adapter/card built in and need to have wireless access, you need to buy a usb wireless adapter. These days they are as cheap as 8$ to 50$.
Hope this helps.
Apr 29, 2014 | Dell Computers & Internet
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
How do i connect the mouse? Belkin Wireless comfort mouse F5l030-BGP I put the usb in and nothing happens
Insert your USB receiver into a USB port on your computer. If you are using a laptop, you'll usually find a USB port on the side. If you are using a desktop computer, it's likely located on the front or rear of the tower.
Wait for your computer to install the drivers. You'll see a progress balloon in the bottom-right corner of your desktop screen. After a minute or so, it should show "Success." If it does not, or if there is an error, visit the Belkin resource to download the drivers.
Turn the mouse over and push the switch to "On." The mouse should automatically communicate with the USB receiver. Test the mouse to determine if it has. If the mouse does not work, press the "Connect" button on the receiver and then press the "Connect" button on your mouse. The mouse should be functional.
Mar 22, 2011 | Computers & Internet
Tower wont work but usb ports still work
ummm mabey your monitor is bad...do the num lock key or the caps lock keys light up...mabey you need a new video card..numors things can cause this delema
Nov 15, 2009 | Computers & Internet
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse bx300008 Logo
1,140 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
