Question about HP LaserJet 3050 All-In-One Printer
My printer went without a problem . zaistalowalam drivers and stopped me wogole walk, none of the button does not work, it shows only the string-pakart hawleet what do I do? Does anyone know how to write in Polish
    Sergeant:
    Champion:
  • 236 Answers
Sounds like the formatter board or LVPS is bad
Posted on Mar 19, 2011
Canon Pixma MP160 stopped working, showing E 2 - paper is not jammed - Printer is NOT hooked up to a computer - only used for scan and print in farm shop (heated) - suggestions? It is an oldie but a...
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
  1. Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
  2. Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
  3. While holding down the "Power" button, release the "Stop/Reset" button.
  4. Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
  5. Click the "Stop/Reset" button four times
  6. Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Feb 18, 2015 | Canon PIXMA MP160 All-In-One InkJet...
How do I setup my printer wireless to read my laptop when asking to print
A couple things to check............1) You need to go into control panel, and "add printer". It will walk you through it. Make sure your printer has the wireless button pushed so it can read it. Your printer will then show up under "devices" under 'hardware' in the control panel.
2) Some printers you have to have connected to your computer with an ethernet cable the 1st time to get it set up. 3) do a windows update to make sure you have the correct driver. Most printers come with a disk that will walk you through everything. 4) Just make sure your wifi button on your computer (mine is f12) is turned on also........ 5) Some printers are not compatible with certain operating systems...i.e Windows 7 or Windows Vista... Make sure yours is. If not, go to the printer website and look for support. Sometimes there is a generic driver you can download that will work. Finally.........Sometimes you just have to keep trying things, as it can be a pia if you haven't ever done it before! :
Nov 12, 2014 | Lexmark Interpret S405 Wireless All-in-One...
Both of my ink cartridges went out at the same time and i only replaced the black. now it has an error saying it will not print because i need to replace the color ink cartridge. but i'm trying to...
It depends on the model that you have. You can try one of the following to reset the ink counter and the printer will show a full color cartridge.
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button
Aug 30, 2011 | Office Equipment & Supplies
How can i reset the Ink Level on Canon MP240
Here are three methods that have worked on Canon printers. Have no fear. None of these will cause damage if they do not reset the ink counter. Once reset you will have to monitor the cartridges by weight, as the system will always show them to be full.
The first is basically a modified version posted for the MP460.
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470 to get the test sheet).
11. Open the cover.
11. Now open cover
14. Close cover
Mar 09, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Canon Pixma iP 6600D printing problem.. went to print a scanned document .... paper began to feed in askew from autopaper feeder . Printing process stopped. the process was repeated a couple more times...
To fix the paper feed problem, Clean / rub each roller with a damp cloth with a dab of detergent.
Check for paper residue , especially near the paper empty flag,
Then reset the printer:
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 29, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Epson sx 205, can't change the cartridge
With the power on and the lid up, click on the red stop (left panel). You will notice the cartridges move to the left and then they come back and stop halfway. Afterwards you should be able to slide the cartridges manually with your hand to the larger area on the right where you could do the cartridge change. Once you've moved it to that area just the lift the cover where the arrow is.
Jan 12, 2009 | Office Equipment & Supplies
Scanner problem
Try uninstalling and reinstalling the scannner. Scanner's can be tough. Try disconnecting USB cable and reconnecting too. How recently did the scanner work? Try reinstalling the scanner software/driver. Also see if you can trouble shoot by right clicking on scanner icon from control panel, scanner.
repost if none of these work. thanks.
Sep 02, 2008 | Sharp AL 1631 Copier
EPSON STYLUS C86
Let's Try first if it can print without using your computer just to check if printer is working fine by itself.
step1
Make sure its not connected to the computer and there is paper loaded on the printer. Turn off printer, press and hold paper button (middle button) then press and release the power button (right button). If you can see a flashing green light release your hold on the paper button.
If it prints by itself good go to step 2 if not check what lights do you see. Solid red light on ink light (tear drop button) means one or more inks is empty. Epson printer will not print if one or more ink is empty.
step2
Check if computer can detect printer goto start/control panel/systems/ click on hardware tab and click on device manager
On device manager click on Universal Serial Bus controllers press on the "+" sign check if there is USB printing support on it
Check if there is a mark (ie. ?, !, red x mark). If none good there is no conflicts. If there is a mark right click on USB printing support and click on update driver and install recommended
Oct 21, 2007 | Epson Stylus C86 InkJet Printer
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
HP LaserJet 3050 All-In-One Printer Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
