Question about LG WM2487H Front Load Washer
I have an LG WM2487H*M washing machine and it won't drain. I checked the drain filter and it is fine. I drained the water out from the front of the washing machine next to the drain filter, tried adding some vinegar to the washing machine itself and doing a hot wash, but the water still doesn't drain. I noticed some high buzzing sound when it was draining for many washes before it stopped draining (could that indicate something?). Does this sound like something is clogged in the drain hose (if so, how can I unclog it?) or is my pump faulty (machine purchased in late 2007, not sure how long they last, how can I replace it if this sounds like it's the problem?). Thanks.
stradeteox
  • 88 Answers
SOURCE: clogged drain(?) LG WM2233H*
Check on the back of the unit just below where the 2 water lines come in. This is the location of the tub air vent. If you see evidence that water has trickled out of this vent then you probably had an oversudsing issue.
There is a mushroom valve inside the machine that seals off this vent when the machine is spinning out. Often, if oversudsing has occurred this mushroom valve will get soap residue on the shaft and keep it from shutting all the way. When water leaks out this vent on the back it tends to make its way under the machine and pools up right in front of the drain filter housing.
If this is your case, just make sure you are using an HE (high efficiency) detergent as it is low sudsing. Also make sure to only use 2-3 tablespoons per load.
Hope this helps, please rate my solution or ask additional questions if needed.
Posted on Jan 12, 2009
  • 99 Answers
SOURCE: LG Tromm Model # WM2075CW doesn't drain - water everywhere!
This is joyce
I hope you have not been waiting long for this answer, go to the website lg.com dowload your document on your washer put in your model # first and then it will give you all the info you need on that machine even trouble shoot it and codes. I hope this helps.
thanks,
joyce
Posted on Feb 07, 2009
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
  • 3741 Answers
SOURCE: washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 20, 2009
  • 91 Answers
SOURCE: My LG Front Load washer
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Posted on Aug 29, 2010
Washing machine making funny noise and will not drain.
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump preventing the impeller from turning, or in the drain hose. Check both for an obstruction before replacing the pump.
Sep 23, 2014 | LG WM2487H Front Load Washer
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
We have a LG washer, model wm2487hwm, seems like it is not spinning oiut the water like it used to, clothes seem to be wetter than previously, whats the problem?
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 08, 2011 | LG WM2487H Front Load Washer
The front drain pump filter is plugged with sand and other build up. and then i'm getting a grey gunk in the washing drum, i'm assuming it is b/c the drain pump is blocked and it is coming back in the...
the best way to drain the machane is to lean the machine back prop something under it and then using a bucket take the drain hose out an bring it as low as you can to the floor. This will make it easer for you to open the front at the bottom an clean the drain trap ,it is possible that there will be a little water left in there good luck
Apr 13, 2011 | LG WM2487H Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Aug 23, 2010 | LG WM2487H Front Load Washer
Washer machine not draining the water after wash cycle
either pump is bad or something is blocking it. did you pull filter at bottom left corner and clean look inside make sure nothing in there.
the little hose is for draining tub
Apr 23, 2010 | LG WM2487H Front Load Washer
Water is not draining out
Check that the drain hose is not clogged.
Access to the drain pump and check the drain pump intake, that is probably filled with debris.
Ensure that the drain pump is working, the pump should be energized directly by a technician to test it.
If the drain pump is fine , and you already tested water level switch, then it is either a bad control board, or a lose contact on the drain pump wiring harness to control.
Feb 18, 2009 | LG WM2487H Front Load Washer
LG WM2487H Front Load Washer Logo
177 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
