Question about LG LS-K1830HL Heat Cool Mini Split Air Conditioner
I will be installing my air con unit and just wanted to know if i need to consider my neighbour before siting unit for noise etc, as i am considering to site it 2 meters away opposite neighbour's window to there living room, on ground floor, thanks carmelo
    Problem Solver:
  • 8 Answers
From my experience mini splits are a very quiet unit. You may need to check local code though, and consult your neighbor first. Better to be proactive over making an enemy.
Posted on Mar 19, 2011
When we should consider recover lost or forgotten Windows password with third-party software? Which one do you know helpful?
When you don't have another available administrator account, password reset disk, when you couldn't make use of command prompt, WinPE, Chntpw etc, when you don't want to reset forgotten Windows password with installation disc, you could consider recover lost or forgotten Windows password with third-party software.
Windows password reset, Ophcrack, Windows Password Genius, and other free or charged software is so much. How to choose one from it? You need to consider its applicable Windows operational system, recovered password length, what devices it needs, advantages or disadvantages etc. You should know how to compare them and make a right choice. And then lost or forgotten Windows password can be recovered successfully.
Refer passage:
http://www.isunshare.com/blog/notes-on-windows-7-password-reset-with-third-party-software/
Aug 15, 2013 | Microsoft Windows 7 Ultimate for PC
Replacement hose for hinari PAC9100 air con unit
I am sorry but fixya has no parts resources of any kind. You can try this site if you are in the USA www.repairclinic.com
Jun 21, 2012 | Heating & Cooling
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
I need to know what are my options if i want to upgrade my gateway 500gr. Mamory, video card, power supply? what else can i do?
If your computer is more than 4 years old and you want a faster computer with a high end graphics card for games, RAM and larger hard disk and Windows 7, then I would seriously consider buying a new computer. You don't need to purchase a new monitor (keep your existing one), this will reduce the costs.
An upgraded old computer would not be as good as a new one, when you consider the costs and time involved with replace hardware and installing Windows on a larger hard drive, device drivers and programs etc.
Dec 02, 2009 | Gateway 500GR PC Desktop
What size duct do I need
there are online formula to calculate what you want
google ---formula to calculate air flow in pipes--
calculation will have to allow for the turbulence and restriction caused by the spiral construction of the tubing and the bends involved so you may have to incorporate several formulas to get the desired result
distance is critical as there are frictional coefficients to be considered as well
I would consider from large shop air circulation systems (as you see in Aldi, woolworths , sears etc ) that a staged diameter difference from motor to exhaust point be considered as that will keep a steady air flow for the length of the tube and a hp rating of 3hp 3 phase as a minimum
Talk with the engineers of shop and factory air conditioner designers and installers to get a close idea to what would be suitable for you
Aug 02, 2017 | Jenn-Air Ventilation System for Custom...
Oil pressure
This doesn't sound good, the pressure sensors fail more often than the oil pump but not with prominent rocker noise. I can't help you locate the sensor but you might want to consider downloading the complete manual for $9 US from this site:
Trade bit manual
The range of oil pressure falls between 30-60 PSI (2-4 bar or ATM). The warning sensors are somewhat useless as they typically will switch at ~ 4 PSI which is pretty much a disaster zone.
Oct 24, 2008 | 1999 Daewoo Lanos
Wind noise on vhs
Hi Claire
Wind noise is very common when recording outside.
Firstly, make sure the microphone you use is uni-directional. This means it will work in the same way that a television antenna does, in that it will pick up sound from the direction it points in, but sounds from other directions will be attenuated. These mics are often used by broadcasters and those in noisy situations, football matches etc.
Secondly, make sure your microphone is fitted with a good foam wind cover. If it already has one, fit a thicker one. This is the single most important thing you can do to cut down on wind noise. You can always get yourself some foam and wrap it around the microphone, right over the top, and tie it with a piece of string.
It sounds a bit wacky, but even pro broadcasters do this from time to time.
Finally, consider using an extension mic cable and positioning it closer to the signal source. Be careful though. If the neighbours are that bad, make sure you are not on your own.
Good luck and best wishes
Helen
Apr 04, 2008 | Televison & Video
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
LG LS-K1830HL Heat Cool Mini Split Air Conditioner Logo
167 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
