Question about RIM Blackberry Curve 8300
It dropped in some water for about 5 seconds and it wont switch on its a blackberry curve
Try to take it apart into the smallest pieces you can and put it in a place it could dry up, to tell you the truth probebly its dead but if its dry and still doesnt want to turn on take it to a mobile fixing store
Posted on Mar 19, 2011
Blackberry curve 8330 it keeps dialing 252525252525252525 It wont stop I have removed the battery several times
Your digit 2 and 5 number pad is broken. Open the front cover (if you dare) and try see what's wrong.
May 03, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry curve wont power on. Worked fine yesterday. Put on charger last night. This morning phone was off and wont power on. Took battery out, then but back in still wont turn on
First charge your mobile for atleast 1 hour,and switch it ON you to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. To perform a clean installation of the BlackBerry Device Software using Blackberry Desktop Manager 4.5 to 5.0, perform the following steps:- 1) Open BlackBerry Desktop Manager. 2) Click Help. 3) Select About Desktop Manager. 4) Click the Device Software tab. 5) Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
Nov 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
My blackberry 8300 will not turn on, recent water damage. It worked before and after I dropped it in water, but now it won't turn on at all.
If your BlackBerry gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Sep 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry Curve 8330 won't turn back on
Pull the battery out and put back in. Then hit the reset button on back panel.
Sep 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
BlackBerry Curve 83can't see the
Hi i would say you are having keypad problems, probably your dropped the unit or some how some moisture gone inside unit. cheap water damage cleaning services for blackberry send it to www.E-Repairs.co.uk They have 90% success rate on blackberry repairs.
Jul 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
My blackberry curve is locked and wont unlock
i would recommend reloading the device software using the desktop software available on blackberry.com
normally a blackberry will not tell you to enter 'blackberry' unless it is trying to wipe the device.
Jul 11, 2009 | RIM Blackberry Curve 8300
Screen lights wont work on blackberry curve 8330
You could open up the phone and inspect if there is something you could do to the screen to make it light up or you could replace the lcd screen either by bringing it in for service which might cost a lot or you could do it yourself which is what I do I find its usualy cheaper to do it yourself I go to http://cnn.cn for all my cellphone parts its high quality and there is a lot of nice OEM parts there.
Kyle
Jul 01, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry curve wont load, it wont go passes the screen with the little hourglass
Hi there!
It's possible that a quick power cycle might help you.
Take the battery out of the device, press the power button 10 times and on the 10th time, hold it down for 10 seconds. This will drain all remaining power that still exists in the Blackberry.
Place the battery back in and attempt to boot the device to its normal state.
Was the device damaged in anyway that might cause this problem? If dropped in water or dropped on the ground from a notable height, you should definitely have a technician take a look at it. You can find a technician at one of your service provider's device support centers. Or, if you don't want to have to go anywhere to troubleshoot, you can contact Blackberry Support on a different phone and they should be able to help you.
Also, if you have a warranty plan, this would be cause to utilize it.
I hope this helps! Feel free to reply if you have any further questions.
Apr 13, 2009 | RIM BlackBerry Pearl 8100
My blackberry 8320 wont turn on no blinking nothing not even
Try a new battery or have your battery charged on another 8300 series phone, then install it in your phone. Typically, if the battery is below a certain voltage ("dead") the charging circuit does not become active, therefore not enough voltage to turn on your 8320. Also if it has been dropped or got water damage, these can also cause that problem.
Mar 06, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
RIM Blackberry Curve 8300 Logo
66 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
