Question about Home
Bathroom cabinet pull knob is stuck. Slot in screw is stripped out. Have put all new knobs on cabinets and drawers, this is the ONLY one that can't gt off !
    President:
  • 1,273 Answers
Hello, annemoss, W/D here.
There is a product that is sold for stripped out screw heads. It has a grit in it, and you place a drop of it on the screwdriver before you put it into the stripped slot. The grit fills the strripped void and allows the screwdriver to get a good bite. The brand I have used is called "Screw Doctor", but there are others. The large "box" hardwares will have this type product, as will Sears.
Another alternative is to drill the screw head through to the shaft of the screw from the back side. Use your old screws that you have already taken out to determine the proper drill bit size. The aim with this method is to remove the screw without making the screw hole too much larger.
Best regards, --W/D--
Posted on Mar 19, 2011
Remove stuck screw
If the screw head is stripped you will have to replace the knob and screw. Try holding the screw head and turn the handle is its a single knob. Otherwise use a hacksaw or dremel tool and cut about 3/8" away from the door surface, once you cut through you can use a small punch to push the screw through the door then pliers to pull it out. Alternately you could use a dremel tool and carefully grind the head of the screw down until you can brake the head off and pull the handle and screw out through the front.
Jun 19, 2014 | Top Knobs Hardware & Accessories
How do you remove drawer from chelsea vanity cabinet. It's a single soft close large pot style drawer. It's doesn't seem to unhinge at the end to lift out. It's a Forme Bathroom one
pull the drawer all the way out Lift the up front slightly and lift the drawer rollers over the track rollers in the cabinet. Replacement is to hold the front up while you place the drawer rollers in the track over the track rollers , push in slightly ,lower the front onto the rollers and push all the way in
May 04, 2013 | Furniture
Where can I get some cool handles for my new kitchen cabinets?
Here is a link to some amazing and inexpensive knobs from Anthropolgie. I bought the bubbled glass knob for bathroom cabinets and I love them.
Jan 31, 2013 | Hardware & Accessories
We can't remove the door knob from our bathroom door because there is no screws. Please advise
The knob part has a small slot on bottom side near the brass plate.
Get on the floor and look up.
Locate slot. Take a photo so you can enlarge what you see.
There is a metal tongue that is clicked down into the slot. This holds the knob from coming off.
Use small screwdriver to push up the tongue at the same time you are pulling to remove the knob.
Once the knob starts coming out, you have to pull screwdriver out of the way.
Knob comes off.
Brass plate covers the screws. Use screwdriver on edge of brass plate to remove. Notice brass place has small indents where a screwdriver can fit.
Once plate and knob are off, you have access to screws.
Take photos as you go so everything goes back smoothly.
When putting knob back, the tongue might have to be pushed so knob goes on.
Push knob into place until you hear tongue click into slot.
Apr 02, 2011 | Hardware & Accessories
Kenmore Model # 110.26842691 my Heavy Duty Wash setting is not working.. is it a bad switch
The cycle switch is faulty or the Heavy Duty Wash terminal connection is loose. Check it first before ordering a replacement part.
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
The console is held to the cabinet by two screws hidden under the console end cap trims. Remove the end cap trims to access the screws by pulling or prying its top off the console.
Remove the screws at the front bottom corners of the console. Once the screws are removed, slightly pull the console to the front then flip it to the rear of the washer to access the switch.
Check the switch for any physical damage. Disconnect the wiring harness from the switch terminals and clean both the terminals and the connector. Reseat the connector several times to ensure good connections.
Replace the switch (part #3949181) when damage is found or when cleaning and reseating the connectors do not resolve the problem.
Pull the knob off the switch shaft and release the switch from the console. Install the new switch in place and insert the knob to the switch shaft.
Flip the console back to the top of the cabinet and align the tabs in the console end caps with the slots on the cabinet. Insert the tabs into the slots and secure the console to the cabinet with the two screws previously removed.
Mar 20, 2010 | Washing Machines
The Hold to start button is not starting the washer anymore. It used to work but it no longer makes the click that used to start the washer. It seems to be stuck
The user interface board is not serviceable and it requires to be replaced when it is not working properly or when a button is stuck. The procedure is quiet easy and you can do it yourself.
Disconnect power to the washer prior to servicing to avoid electric shock.
Remove the three screws attaching the rear of the top panel to the back of the washer then slide the panel rearward, and then lift it off the washer.
Disconnect the 7-terminal user interface ribbon connector from the left side of the central control unit.
Pull the dispenser drawer out until it stops; press down the release tab then pull the drawer completely out of the washer.
Remove the screw in the recessed hole at the left of the drawer opening. Press and release the tab securing the right side of the console to the cabinet.
Open the washer door then insert the blade of a flat-bladed screwdriver into the slot at the bottom center of the console then push the console up to release the tab attaching its bottom to the cabinet.
Gently pry up and release the top of the console then pull it off the washer.
Pull the cycle selector knob off the control panel then release the tabs securing the user interface/LED assembly to the control panel. Lift the user interface/LED assembly from the control panel once all of the tabs are released.
Inspect the Hold to Start button and the alleged stuck membrane in the user interface board. Replace the button if it is broken. Try your luck by trying to unstuck the stuck membrane. If no luck at all, replace the user interface assembly.
Install the new user interface/LED assembly into the control panel by inserting it into the tabs from one side to the other until it is completely secured, and then reinsert the cycle selector knob.
Align the console tabs with the slots in the cabinet then insert the tabs into position. Secure the left side of the console with the screw previously removed, and then slide the dispenser drawer back in place.
Reconnect the user interface ribbon connector to the central control unit then slide the top panel back into position and secure it with the three securing screws.
Note: The user interface assembly part number may differ from version to version of the same model. The version is indicated by the last digit of the model number so make sure to indicate the complete model number of your washer located on the left side of the door opening.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bathroom doorknob stuck in locked position.
I will tell you how to fix 'em. Open the Door Knob with a screw driver, gently pull aart the two knobs once open, then look for a long sliding rod, pull one knob away, twist the Knob untlil it is in unlock position, put them back together to test if it slips properly. If it does not, there is something preventing the rod from rotating freely. Try to ensure it rotates freely. Then screw back together :)
Nov 18, 2009 | Hardware & Accessories
How do i change the wick?
You need a pair of Pliers, a flat-tip screwdriver and a plastic bag (for old wick)
ALSO - make sure the tank is empty (or as close as possible)
1. Turn the control knob to OFF.
2. On the left and right side (bottom, just under the wire cage are two cabinet screws. Remove these.
3. Using the handle, lift straight up to remove the cabinet (entire upper assembly)
4. Gently pull off the wick adjustment knob (you will need to push in the little square button.
5. Remove the "dressing plate" (the ring about 3" high) that the "Off" "Low" and "High" markings. The chain attaches this the fuel cap, but you don't have to remove the cap. Just set the "dress plate" ring aside as far as the chain lets you.
6. Either trip the manual shut-off or push against the wobbly pendulum to the left of the control knob shaft to drop the wick all the way down.
7. Remove the four wing nuts that holds the heater on the wick assembly and carefilly lift teh sick assembly from the heater.
8. Reset the automatic shut-off, put the know back on temporarily and raise the wick all the way.
9. Turn the Wick Assembly upside down. Place the white plastic strip, packed with the new Wick, on the Wick Cover to protect your fingers.
10. While holding the Wick Assembly upside down, pull off the Wick Cover with a sharp tug.
11. Remove the Wick while folding it to the inside. (Remove the Wick Sleeve together with the Wick).
12. Take the new wick and insert the Wick pins into the three holes of the Wick Sleeve. (Make sure the short portion of the Wick is UP.)
13. Attach the Wick wo the retainer teeth of the Wick Sleeve stick into it, making sure the Wick fits evenly arount the inside with no wrinkles or bunching.
14. Fit the Wick and Wick Sleeve back onto the Wick Guide, making sure you fit the pins through the slanted grooves of the Wick Guide and Press on each of the three pins from the back, making sure they are inserted securely through the holes on the Wick Guide. (This is where most people screw up Wick Replacement, so make sure you get this right)
15. Turn the Wick Adjustment Knob to make sure the Wick slides up and down freely. (Note, the wick should automatically be set to 3/8 of an inch when fully raised.)
16. Turn the Wick Assembly upside down and replace the Wick Cover by: Align the four tabs on teh Wick Cover with the four screw holes on the bottom of teh assembly and snap it into place.
17. Hold the Set Lever to down position with your finger.
18. Remove the protective strips from the Wick Cover. Turn the Wick Adjustment Knob to the fully raised position and light pull on the "skirt" of the Wick to remove any slack. Then press the skirt lightly onto the teeth on the Wick Cover to hold it in place.
19. Replace the Wick Assembly on the heater WITH THE WICK RAISED. Replace the wing nuts, tightening gradually, tightening opposites sides first(If counting clockwise, tighten screw 1, 3, 4, 2 - go through several rounds, tightening gradually so it seats evenly
20. Before further reassembly, trip the Auto shut-off and reset it to make sure it works properly. Test the Wick adjustment knob to make sure Wick slides up AND down freely.
21. Remove the knob and replace the "dressing plate ring.
22. Replace the entire upper assembly "Heater Cabinet" and repalce the two screws. Replace the Wick Adjustment Knob.
Oct 11, 2009 | Corona 23-DK Compact Heater
I HAVE A JUICER MODEL #JE95XL ITS ONE YEAR OLD,I
Go to Lowes, to the cabinet knob dept. Get a cabinet knob that matchs the holes in blade. You can always bend the screw a tiny bit if needed to fit. Put the screws into cabinet knob, and tighten. Cut the heads off and you are ready to go. They have a knob that is stainless steel, just a flat piece across the top, an 2 straight pieces that go down. I think it was $2.97. It gives good grip, and takes the blade right off.
Aug 21, 2009 | Breville JE95XL Juicer
Washer is stopped in spin cycle.
first unplug machine. you will need to start by taking 2 screws out of the face of the machine. flip face back and unplug the lids witch from cabinet. you will see 2 gold clamps you will need to pop them off and then your cabinet should pull forward and cabinet will come off. at front bottom you will see your pump, take 2 clamps off pump and move to the side and then take wire harness loose from the motor. the motor has 2 clamps holding it in place also pop those eff, sometimes their will be a screw you need to take out before the clamp comes off but you will see. soon as motor is off you will see the drive coupler. it has 2 sides to it and a rubber like center. either it has broke teeth on it or the rubber part will be destroyed or where the shaft goes into coupler will be stripped.
Jul 03, 2009 | Washing Machines
Home Logo
126 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
