I unplugged my murphy 19 inch, model no;DTV 1500V tv and now once i plugged it back in i get no sound but the picture is good. can you help me with this.
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
Fujitsu
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
  • 718 Answers
SOURCE: insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Posted on Feb 23, 2009
SOURCE: LCD TV PICTURE HAS GONE OFF BUT NOT SOUND?
when ours went the repair man went over boards on back with magnefying glass and replased 2 capacitors that had blown £20.00 he charged us
Posted on Jun 19, 2009
SOURCE: proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
Posted on Jun 22, 2009
Tv (plasma) made loud pop then went black, turned off still no picture but has sound through different channels. Happened before and dish said to reset box? thanks
That's an interesting issue you posted, yfz45011959! Try unplugging the receiver's power cord from the outlet for at least ten seconds and then plugging it back in. If that doesn't fix the problem, let me know what type of receiver you have. The model can be found on the front panel in the bottom left corner.
Hope that helps!
Jul 26, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Our Mintek HDTV Mod# DTV-323. WIth an internal DVD Player keeps comming on when it is in tv mode. there is a disc hung in it. It has not worked for a long time. How do I fix this problem or can the dvd...
2 answers 1 usually you can remove a stuck disk by finding the tiny pin hole on the dvd insertion tray and pushing it in about 1/2 inch this will force open the player so you can remove the stuck bootleg dvd you put in it. step 2 is you can unplug the tv lay it face down and remove the stand and the back screws from the tv there about 20 screws once removed you can pll the back off the TV and find the dvd module and carefully disconnect the moduler plugs connected to the dvd
Feb 20, 2018 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Samsung 933hd tv. . .once i plugged it it turns on and it gives the sound but the whole screen turns white. . .any suggestions?
The screen turns white because defective T-Con. Mostly 19 inch model doesn't have PCB T-Con. My suggestions is , call samsung cervice center.
Mar 14, 2011 | Samsung 933HD 19 in. LCD TV
I have a 19 inch emerson lcd tv that has no picture and as u plug it in the tv makes a whinning sound but as soon as u unplug it the sound goes away
More than the tv power supply board have problems in this tv,don't know yet.But the whinning sound,the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.First must see how it turn out.
Dec 08, 2010 | Emerson LD195EM8 19 in. LCD TV
Tv turn on no pic or sound
Try unplugging it for about half an hour, plug back in, if it still does not work, you will have to open it up and do some troubleshooting.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Jun 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Pressed re tune on our 19 inch lcd tv with built in free view now the tv will not work tv on standby will not turn on no picture no sound
Hi friend,
Can you mention your product brand and model name so that an exact solution can be provided.
Your new TV has a digital tuner built in, which means it is ready to receive the Freeview signal by simply plugging it into your aerial socket.
I guess you just need to switch it off then unplug all the cable. leave it for an hour then again reconnect them as directed. I hope this will work.
Gud luck.
Oct 03, 2009 | Televison & Video
Vizio LCD DTV 32 inch. Model L32. I can't 'scan' for digital channels. When I go to DTV, then Menu and scroll right or left to "TV tuner setup' I get a blue screen and nothing else. No key on the...
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Mar 23, 2009 | Vizio L32 32 in. LCD HDTV
info
menu
mute
power
HTH
Oct 24, 2007 | Televison & Video
Tv went off.
i have the exact same problem except with a different tv model.and i cant get help.
Jun 01, 2007 | GE 19GT357 19" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
