Question about Craftsman Garden
My craftsman gt5000 25 HP kohler ran then engaged the blades and it died now it will not even turn over I tried to jump start it and it acts like it has no power to key switch or maybe problem with electric clutch ?
    President:
  • 3,074 Answers
OK. there is a inline fuse, it is usually on the red cable leaving the battery, if will be close to the battery, follow the cable until you see the fuse. sometimes they are located under the plate of the the transmission(middle between seat and steering wheel) Hope this helped Tim
Posted on Mar 19, 2011
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
How to fix my craftsman riding mower, whcih dies after engaging blade
make sure blades not jammed. with mower off, try turning blades by hand.
it could either be a safety switch in the seat or for the reverse paddle.
make sure its not in reverse when you attempt to engage blades.
you should be able to bypass both switches with a jumper wire for testing purposes. if it works with jumper, replace the switch(s).
Sep 01, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Why would a person need to jump start a battery on a john deere stx 38 to start it,if the battery is good ?
You have indicated a bad battery. There is enough charge in the battery to start and run buy not enough when you engage the blades. Check the battery by load testing it and checking with a multi-meter.
Jul 12, 2014 | Craftsman Garden
Craftsman dlt2000 20 hp kohler runs great until i try to engage blades pull up on the switch to engage and motor bogs and stalls
Now is a great time to remove the deck and sharpen the blades! In the process, you will find your problem. Look for clogs, seized bearings, freely rotating belts, etc... The problem is in the deck or drive belt. Hope this helps!
Sep 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Apr 24, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
233 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
