Question about Gaggia MDF Coffee Grinder
Grinder is slipping.
While grinding some coffee suddenly my grinder statred to make a noise like it was jammed. I immeadiatly syopped the machine, shook it ant tried again for just a few seconds, same problem. I took the machine apart to clean it out and found a small coffee bean sized pebble. Now after cleaning and reassembly the bottom plate is slipping. I have not taken the grinder appart to see if something is stripped under the brass plate that the holds the burr. My question is can this be fixed? Could about ten seconds of trying to grind a pebble ruin my grinder.
I am pretty handy and would like to do this myself.
  • ChicagOkie Aug 02, 2008
    Sorry: I This is a Gaggia MDF. The grinder is 4 years old and is used about four days a week. I am about to try to get the nut that holds the bottom brass plate/burr assembly off. I think the problem lies underneath. I wish there was a schematic I could see to get a picture of how it goes together before I take it apart.
  • Kelley Hopper May 11, 2010
    What brand of grinder is it?
    Novelist:
  • 137 Answers
  1. take out bean container
  2. disassemble 3 philips screws and take plastic out
  3. rotate the knob to try to get out the upper holder of burr. if it does not rotate than disasemble the knob and the gears(plastic big one is attached to upper holder of grinder, the other is together with knob.
  4. tru to rotate it manualy, with help of extra srews puted in gear holder holes.
  5. when you get it out, carefuly clean it, look for metal parts and stones(wich sometime comes with coffee)
  1. turn on the grinder and attach gently one marker to lower burr during spining. after you stop grinder, look if it is perfect circle marked in burr. if it is not than marked side is higher. you should consider getting it ok by putting adhesive paper under lower burr and check it again.
good luck and carefuly.
Posted on Apr 04, 2009
Grinder is not working. Makes a clicking sound
There is probably a stone jamming the grinding teeth. You need to take the top off the grinder and pick/vacuum everything out of in the grinding department. The top of the grinder has the stationary grinding teeth attached to it.
Oct 08, 2015 | Krups Coffee Makers & Espresso Machines
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
While grinding heard noise as if a foreign object was in the grinder. The grinder started smoking. Unplugged grinder. Any suggestions on repair?
You will have to dismantle the grinder, removing the 2 bolts at front, then working your way back to the grind chamber, You can find the diagrams for the machine on bunn.com
Jan 16, 2011 | Bunn -o-Matic G3 (3 lb. Commercial Coffee...
Rock stuck in grinder. just spinning noise when it
It is not a healty sound,seems either the gear cogs slipped or the plastic base that holds the lower blade of the grinder is broken.
Jan 02, 2010 | Saeco Talea Giro Espresso Maker -...
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
My Bunn Grinder sounds like it is jammed. I have power but no mov
First turn grinder to coarse setting and try grinding some white rice through it, that will clean out the coffee oils, if that does not work then the you will have to open the grinder and clean out the burr chamber and the spout for the grounds.
Apr 21, 2009 | Bunn Coffee Grinder
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Coffee machine will not grind the coffee beans?
Since your grinder makes noise and the problem occured suddenly, I would rule out a grinder problem. I am guessing that your grinder runs 10-20 seconds before it stops. If that is the case you need to look for a obstruction in the grinder or a failed microswitch on the doser. Either of these could cause the problem.
Dec 13, 2008 | Saeco Vienna SuperAutomatica Coffee...
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
422 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
