Question about Sharp AR-5320 Black and White Copier
Why this solution does not clear the problem "press these buttons in order #, interrupt,C , interrupt. when display goes off enter 14 then start button it is ok"
  • 132 Answers
Ok that is the clear button for the toshiba e120 i will try find the reset code for the sharp
Posted on Mar 19, 2011
Red light display man and star
Ugay: on FixYa.com (older entries) they said,: Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button. Another guy said: "change the main charger because based on my experienced it has an arching problem "
another said: "Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser
May 14, 2015 | Sharp Office Equipment & Supplies
Microwave does not work at all. Shows "PF" in display.
"PF" on the display is an indication that your oven experienced a power interruption. Normally, the error code can be cleared by pressing the CLEAR/OFF button. You may have to reset the time. This is accomplished by pressing the CLOCK button, entering the time on the keypad, then pressing CLOCK again. If this does not clear your problem, please let me know. I hope this helps you.
Jul 26, 2011 | Hotpoint RVM1435 Microwave Oven
Sharp Al-800 H4 Error Code
Press : CLEAR key - INTERRUPT key - O - INTERRUPT key.
The copy quantity display goes off and the machine is ready to receive input of test command number.Enter the two digit number to select the test commands.The test command number entered will be displayed in the copy quantity display.Press the PRINT switch.The operation corresponding to the entered test command number will be performed.For the test command 13 and 14 since test commands 13,14 are used to clear the contents of the diagnostic status (U1,H3,H4)stored in the LSI,the diagnostic mode will be automatically canceled after completion of the test commands.
Jul 30, 2009 | Toshiba e-Studio120 Copier
Call for service H4-00
please do the following : press #, interrupt, C, interrupt when display goes off enter 14 and pess print button
Jan 23, 2009 | Toshiba e-Studio162D Copier
Sharp ar-5320e error code U2
please press these buttons in order #, interrupt,C , interrupt.
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error h200
H2 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
enter 14,
Hope that helps...
Lbcoaster
How do u reset the Sharp copier AR-153E? wat buttons do u push?
For error codes:
You enter simulation by pressing #,interrupt,c,interrupt in sequence display goes off, then no. 14 then start key.
Hope that helps...
Lbcoaster
Jul 14, 2008 | Sharp AR-153E Copier
Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Jul 02, 2008 | Sharp SF 2020 Copier
Sharp AR-5320 Black and White Copier Logo
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
