Question about Spectra Pelco Spectra Iv Sd4cbw-smw-3 Ptz Dome 23x Dn Surface
I have a pelco spectra 4 camera hook into my company's entranet and I have a KBD300A controler the camera is also conected to a monitor just for the camera by a coax cable. The camera worked ok through the coax but it was not working very well on the plant network, one of the other electrican decided to try to go to an older software update because we started having problems after he did an update,when he did this it locked up the camera so even the controller does not work it just pointed down and gave us a configure failed note along with the camera specs on the screen. It still has a live picture but when we try to redownload the original software it is unable to find the camera even when hooked directly to the camera.Is there any way to do some kind of a reset to this thing to maybe start over or what should i try next? and i did try pulling the power and that did noting.
How do I reset KBD300 pleco keyboard
To initialize the keyboard, wait five seconds after powering-up the CM6700, enter the number for the
monitor you are viewing (1-4), and press MON. The LED display shows the number entered.
NOTE: You must re-initialize whenever power is cycled.
Source: http://www.jmacsupply.com/v/vspfiles/files/PMFiles/Pelco/Instructions/KBD300A-InstallationManual.pdf
Jan 15, 2015 | Pelco Kbd300a Pushbutton Control Keypad W/...
Tip
Pelco PMC10A Monitor 10 INCH COLOR HIGH RESOLUTION
We bought 6 Pelco PMC10A Color Monitors and they are working 24 hours a day. Suddenly after the warranty was over, the screen went totally black on 3 of them. After searching a while for the cause, Pelco seems to have used the wrong capacitor on their board close to the fly-back. They used a catalytic capacitor G-LUXON 4.7uf 50v and they have all busted by just looking at it on the board. I replaced the defect capacitor with a 4.7mf/250V Metallized Polyester Film Capacitor for about $2 each. They are now fixed! Hope this will help someone that has the same problem as I did.
REF: http://cgi.ebay.com/4-7mf-250V-Metallizd-Polyester-Film-Capacitor_W0QQitemZ220150073474QQihZ012QQcategoryZ4662QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
on Dec 03, 2007 | Pelco Pel Monitor 12" B/W
I have 3 outside cameras (SSC-12C) hooked up need cameras
i recommend pelco day night dome camera they are cheap and the resolution is great. they are originally bnc type connector which usually take rg59 or rg6 coax cable but if you have like cat5 or some other kind of stranded wire you can by a balum adaptor that takes stranded wire but has a bnc female end. now with your monitor they make a cheap device called a multiplexer it takes bnc connectors and to hook up to your monitor you can use regular adio video cables like for your vcr. the multiplexer also lets you scan thru your cameras one at a time or have all three up or it can scan thru by itself like every five minuets.
Jan 17, 2010 | Samsung Weather Resistant Security Camera...
I have a Pelco Spectra mini in a warehouse, we replaced the previous camera with this new one but the PTZ function does not work. The old camera worked for while and stopped. We moved the new one to...
Hi. Did you call Pelco's customer support? They should be able to talk you through troubleshooting the camera to at least determine if this is a defective camera or not.
Aug 18, 2009 | Cameras
Pelco Spectra III PTZ camera wrong fuse?
It is replaceable, as long as no harm has come to the rest of the camera.
Mar 14, 2009 | Pelco SD53C22 Smw 0 Spectra III Se White...
Power went out now my pelco kbd300 isnt working
If no power, it must one resistor of power interface circuit burnt. you need to send it for repair.
if it can be powered up, just can't cotrol. you can try to press the key of F5(AUX OFF), and powered it and hold "AUX OFF" for more 3 seconds and release. this mothod is used for calibrate the joystick.
Mar 12, 2009 | Pelco KBD9000 Keyboard
Installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Aug 18, 2008 | Cameras
Spectra Pelco Spectra Iv Sd4cbw-smw-3 Ptz Dome 23x Dn Surface Logo
443 people viewed this question
Top Spectra Home Security Experts
Lawrence Oravetz
Are you a Spectra Home Security Expert? Answer questions, earn points and help others
