On an hp keyboard, what is the light in the top right hand corner next to 1 and A, there is an arrow pointing down towards a straight line? How do I switch if off?
    Problem Solver:
  • 5 Answers
Sounds like the "Insert" button. You need to find the "Insert" key and hit it to toggle this off and on
Posted on Mar 19, 2011
Setting the timing gears on stihl fs110r gas trimmer
Hello there, on the flywheel, between the fins, to the right of the magnet there is an arrow. This arrow points toward the closest ignition unit mounting screw (centre line of the engine) or spark plug when the piston is at the top of it's stroke - which is ware it needs to be to set the cam timing. On each side of the face of the cam there are two arrows facing towards the gear teeth, these line up with two raised lines cast into each side of the cam casing. Another way to align the two components is to set the pointy part of the cam lobe straight up or straight down. Reassemble the followers, push rods and rockers, sparingly apply a good quality automotive sealant to the cam cover - use the groove as a guide. Once that has been done the valve clearances can be set - 0.1 mm with the piston at the top of it's stroke and with the valves fully closed, not on the rock ie exhaust closing as inlet opening. You should replace the cork gasket and copper sealing washer as well. These engines will not run if air is getting in passed a leaking gasket etc.
Good luck.
Nov 11, 2013 | Stihl Garden
Dell inspiron right hand margin cut off
It is more likely that the window got moved to a point where the x, restore, and minimize buttons don't show than it is that a portion of the whole desktop is cut off. Right-click on the icon that represents this window in the task bar, and click maximize. If that's not an option, choose move, and then use the down and or left arrow keys to reposition the window where you can see the minimize, restore, and x buttons, and then hit enter on the keyboard.
Mar 02, 2012 | Computers & Internet
Hi I have a H P model mini 2102 I'm sure the keyboard is defective how do I get the covers off so I can remove the keyboard?
Rick I would like you to download the Service Manual from HP Support (Free),
HP Support > HP Mini 2102 > Manuals,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=4097331
At the top where it states - Quick jump to manuals category - click on the blue heading underneath -
Service and maintenance information
Go down to the 8th (Blue) file listed, and click on it -
HP Mini 2102, HP Mini 210, and Compaq Mini 210 - Maintenance and Service Guide.
(It's the newest one. 10 Jun 2010/ 3.53MB )
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
If you are aware of the following disregard;
At the top of the PDF file is the PDF page number box. It is to the Right of the Down Arrow.
The page you want is Page 52.
You can use the Down Arrow and arrive at Page 52, or:
1) Put your mouse cursor in the page number box. Left-click once. What is in the page number box will be highlighted in blue.
2) Type 52
3) Press the Enter key.
You can also use the Bookmarks menu on the left.
1) Left-click on the + sign next to - Removal and replacement procedures
2) Then left-click on the + sign next to - Component replacement procedures
3) Scroll it down, and left-click right on Keyboard
From the Service Manual, and me:
A) Remove ALL power to the mini laptop. Remove the AC adapter (Charger) and Battery
B) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, you can substitute with a clean egg carton.
Label each egg holder.
SOME screws look VERY similar to other screws. Advise DO NOT mix them up!
C) I suggest laying a towel on a table. Lay the laptop on it. Prevents scratching the table, and the laptop.
Laptop closed, turn the laptop over, lay it on the towel, bottom side up, Battery Compartment facing you.
D) Remove 3 Philips head screws.
One at each top corner, one in the middle (Page 54)
E) Hold the laptop closed, turn it over so the Front is facing you.
Lay it down on the towel. Open the laptop as far as it will go.
F) Lift the back edge of the Keyboard. The back edge is the edge near the LCD screen.
Caution! Use care!
There are tabs in the Front of the Keyboard. These tabs are plastic. They insert down into the Palm Rest Cover. (Top Cover)
If you lift the Keyboard straight up at a 90 degree angle, you risk breaking these tabs off, and also may damage the Palm Rest Cover (Top Cover)
Also there is a Keyboard Cable attached to the Keyboard, and to the motherboard.
G) The Keyboard Cable does NOT remove from the Keyboard. It removes from the motherboard.
The Keyboard Cable is a FFC.
Flat Flex Cable.
It Does Not have a connector on the end.
The FFC is a flat plastic sheath with wires in it laid side, by side.
At the end of these wires are contacts. Usually gold plated.
This end is inserted into the connector on the motherboard.
NOTE the direction the FFC is inserted into the connector on the motherboard. It MUST be reinstalled in the same direction.
Those contacts on the Flat Flex Cable, MATCH up to contacts in the connector on the motherboard
Even if the cable is twisted over when it was installed, the new Keyboard's Cable must be twisted in the same fashion.
H) The connector on the motherboard for the Keyboard Cable, is a ZIF connector.
Zero Insertion Force.
It is a small rectangular connector that slides apart, but DOES NOT come completely apart!
The top part of the connector slides FORWARD.
Forward towards the LCD screen.
It only slides so far. Approximately 1/8th of an inch.
If the top part is completely removed from the bottom part, the connector is damaged. Motherboard replacement may be the only option!
The bottom part is fixed to the motherboard. (Soldered directly to the motherboard)
Looking Closely at the ZIF connector, you will see a parting line between the two 'halves'.
Ease the top part forward with your fingernails, on the top left, and right corners.
When reinstalling make sure the cable is lined up right, then insert the gold plated contact pins in the ZIF connector, as far in as it will allow you.
Then slide the top part of the ZIF connector back towards you, to lock the FFC in place.
(Keyboard Cable)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 19, 2011 | HP Computers & Internet
My mouse touchpad is locked. Keeps showing a diagram on screen with a red line thru the touchpad??
There may be a button towards the top of the keyboard (one of the ones with LEDs next to them) that turns the touch pad on and off. Otherwise, there is usually a keyboard combination (the Fn key in the lower left + one of the F1-12 keys) that can toggle it on and off as well. Otherwise, in the lower right hand corner, if you plug in a mouse, you should be able to right click the touchpad icon and re-enable it.
Aug 23, 2011 | HEWLETT-PACKARD ProBook 6460B
How to remove keyboard
HP Support > Compaq Presario CQ56-115DX Notebook PC > Manuals,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4308201&
I would like you to click on -
Compaq Presario CQ56 Notebook PC and HP G56 Notebook PC - Maintenance and Service Guide
This is a PDF file.
It may take up to 30 seconds before the first page comes up.
At the top of the PDF file is the page number box.
It is to the right of the down arrow.
This is the page number I will be referring to, and not the manual's actual page.
Go to Page 46.
(In the Bookmarks menu on the left, click,
1) On the + sign to the left of Removal and replacement procedures
2) On the + sign to the left of Component replacement procedures
3) Keyboard )
A) Remove ALL power to the laptop.
Remove the AC adapter (Charger) and Battery.
B) Remove the Memory Compartment Cover.
C) Computer upside down (Bottom facing up), front side toward you,
remove the 6 Philips head screws indicated.
D) Computer back to it's normal position, (Right side up) use a thin, flat bladed screwdriver, and EASE up on the Right and Left BACK edges of the Keyboard.
NOTE*
There are plastic tabs on the Keyboard in the front. (Towards you) These can be broken off if you use the thin, flat tipped screwdriver TOO close to the Front.
The BACK of the Keyboard is lifted up to a 45 degree angle, then the Keyboard is slid back towards the LCD screen, a little. This frees the tabs from the Palm Rest (Top Cover) of the laptop.
NOTE*
The Keyboard is attached TO the motherboard by the Keyboard Cable.
The Keyboard Cable does not come off of the Keyboard.
After the tabs are freed, the Keyboard is rolled over, and laid on it's keys, on the Palm Rest.
This allows both hands (Fingers) to remove the Keyboard Cable from the connector on the motherboard.
The connector on the motherboard is a ZIF connector.
The connector is a rectangular block of plastic, and is composed of two pieces.
The top smaller part moves away from the larger bottom part.
The two pieces DO NOT come completely apart. They do not completely separate from each other.
The top part slides away from the bottom part, but only so far. (1/8th inch?)
The cable coming from the Keyboard is a FFC.
Flat Flex Cable.
It has NO connector on the end that plugs into the motherboard.
Just a flat ribbon cable with exposed contacts.
MAKE SURE you line the new Keyboard's cable up the SAME WAY as the old Keyboard's cable.
Install in the same direction.
(Even if the cable is twisted over)
The ZIF connector's top part locks the FFC in place, when the ZIF connector is closed.
The top part has a wedge design.
Regards,
joecoolvette
Jul 30, 2011 | Compaq Presario CQ56-115DX Laptop
How do i remove the drum and clean the corona?
On the both sides where is your manual feed you will find dent for finger. Pull it towards you and down and doors are open. Now you will see drum unit with toner. Take the center of drum unit and pull it towards you.
Drum unit is in your hand.
On opposite side, on right corner you will see cleaner slider with arrow on it. Take it with your fingers and push it in left/right direction few times (warning : upon finishing is mandatory to leave slider on right side, so arrow on the slider will point to arrow on the drum).
Hope it helps
Feb 03, 2011 | Brother IntelliFax-2820 Laser Fax
What is the symbol with the light indicator for?
That's the Scroll Lock indicator.
While not really used for anything today, Scroll Lock used to serve a purpose in DOS text editors - if it was on, and you'd press the Down arrow on your keyboard, the document would scroll down. If it was off, you would move your cursor to the line below it.
It should also work on Microsoft Excel - try it. Open up Excel, make sure Scroll Lock is on, and press the Down or Up arrows. Now turn it off, and see what happens.
If you don't know how to turn it off, search for a key marked "Scroll Lock" or any short versions of that name. If it's in a different color, you may need to press Fun+ScrollLock for the light to go off.
Aug 10, 2009 | HP CPQ175KB Keyboard
Light on keyboard is on
That is the scroll lock light. To turn it off, look on your keyboard for a button that says scroll and press it and the light should go off. Hope this helps.
Apr 06, 2009 | HP Computers & Internet
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
