Question about Emerson (CKD2330) CD Player
Emerson 3 CD Player MS3108
Will not detect any of the CD's when unstalled, comes up no disk.
Yes, your expert told me there was no fix and to return it to the manufacturer, which I did. I don't believe I would now try your premium assistance program after that first session which did nothing for me.
Posted on Aug 03, 2008
Need a remote
May I get the make and model # to help you more
Apr 17, 2010 | Emerson MS3108 Shelf System
Need operator manual for 3108
You can download/print your manual here:
http://www.emersonradio.com/owners/Music%20Center/MS3108_062806.pdf
Dec 07, 2009 | Emerson MS3108 Shelf System
My Emerson MS3108 door keeps randomly opening. All CD music stops when it opens and it opens within seconds of the previous openings. Is there something I can do?
It is a leaf switch that senses that the door is closed. A C-clamp in the upper left hand corner clamping the door closed will make it work. If you remove the clamp, it will randomly open again. The correct fix is to open up the unit and bend the leaf switch to make it activate earlier and fully close when the door is closed.
Nov 14, 2009 | Emerson MS3108 Shelf System
I created a mp3 data cd using cd-r and it doesnt play. I create a music mp3 and it plays with no problem. What am I doing wrong?
Many cd players do not have the capability to play mp3 data files. They do not have the processing capacity of a computer, which reads data mp3 and converts it on the fly as easily as other data files used to install software, etc.
If you know your cd player to be mp3 compatible, try burning at a slower speed, like 1/2 the speed the burner is rated for, or less (like 4-8x), to see if the cd player will read that disc. If that doesn't work, try another media brand. Some cds are of inferior quality and won't write well enough for mp3 data files to be read well by all players.
See also this article, this one or this one.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 03, 2009 | Emerson MS3108 Shelf System
Remote code for emerson 3cd player
I& do I need it to change c.d.s there a remote that comes with the Emerson mS31OO
Jun 03, 2009 | Emerson MS3100 3-Disc CD Changer
Emerson AV50 says ''NO DISK''
Hi, sounds like you have a dirty laser eye on the DVD player. The eye gets dirty and it won't read movies or function properly. I would recommend a DVD Cleaner CD. I would have you try this before I have you open the DVD Player to clean the Laser Manually. Please try this and Post the Result for me to Review. Thank you
May 19, 2009 | Emerson Audio Players & Recorders
The rubbing Emerson CD player
hello, is this a carosel type loader? they have other internal parts that rotate it for selecting cd,s i understand what you mean.
the reason i say to open the case is incase there is something obstruction the mechanism from going in to the right return position
if you allready checked for this and theres nothing blocking the return cd holding part. then you may need to check this cage assembly for internal broken loose screws or jammed parts.
some plastic parts sometimes break or wear out and cuase the return cage to not load the cds properly. this is a loader issue
your on the right track, it is something with the returning cage
also at times the rubber shock resistant booties on the cd reader & motor assembly they are missaligned or come apart
if a cd dosent sit properly it pushes the drive motor and thats when the rubber mountings can come apart. reader assembly & motor mounts. check for this also.
good luck with your player.
happy holidays
Dec 19, 2008 | Emerson MS3108 Shelf System
Emerson ms9700
one thing that you can do and this helped me when i had that same problem is to take off the top cover and clean the laser lens
Oct 25, 2008 | Emerson MS9700 CD Shelf System
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Jun 30, 2007 | Emerson MS3100 3-Disc CD Changer
Emerson (CKD2330) CD Player Logo
351 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
