Question about Dishwashers
Hi, My Miele G 894 SC will not turn off or reset. The pump just runs constantly no matter what I do. Occaisionaly, the intake/drain light flashes. Water in on. I check the drain inlet. All good. Help!
  • 1462 Answers
SOURCE: Miele g665 sc
i think its daft as well but nearly all dishwashers have this feature. you have a leak somewhere to cause this
Posted on Jun 26, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
joe_lishman
  • 192 Answers
SOURCE: Inlet/drain light flashes on miele dishwasher and
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Posted on Jan 17, 2010
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
Miele 863 sc will not run a cycle, it just hums and says check intake drain which we have cleaned and checked all drains and screens
Something may have made it past the drain, is now stuck in the pump or its' intake. Put a tray under it and remove the drain connection to the pump. Unplug the unit first.
Nov 30, 2013 | Miele Dishwashers
Miele G 811 SC Intake/Drain Warning Light Appears... Checked out all the usual possibilities, drainage blockages, intake issues, impeller spins in both direction... all are clear, drains and fills...
I'm having the same problem with my G 811 SC, and have tried the same things, but there aren't any reset buttons (and I called Miele as well as searched the internet for any combination of buttons for resetting it). Anyone have ideas?
Sep 28, 2010 | Miele G 2732 SCI Builtin Dishwasher
Miele g 892 sc intake/drain light is lite and unit will not operate
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Apr 25, 2010 | Miele G892SC SS Dishwasher
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Miele dishwasher won't drain
try removing the pump cover in the sump to see if it is blocked or jammed. it tells you how to in the user manual.
Jul 16, 2009 | Miele 23 in. Novotronic G841 Built-In...
G 892 intake light on
Reset the program by holding down the start button. It will be blinking. Then try the same wash selection and start it. If you wired correctly the drain pump will run 30 seconds. If the intake light comes on in 5 seconds and the drain pump is still running then you have a leak. Miele dishwashers have a safety system that catches water and triggers the alert. Ifthis is the case, there's nothing you can do but get a repair person to pull the machine out and find the leak. If the pump does drain only 30 seconds, then it will stop the pump and let water in. If it fills okay then it will circulate the water and if you haven't oversudsed it [ Energy Star machines use much less water and therefore make much more suds if you fill up the dispenser too high with detergent ] the suds will not trip the pressure switch. Otherwise it will start to heat the water. If the intake light comes on again it's important to know when it does. The computer inside evaluates 100's of steps. The Techs at Miele will need to run it with you on the phone. They have scripted access to the electronic memory and you participate to find the information. They can determine if you can fix it or not.
Apr 15, 2009 | Miele 24 in. G892SCU Plus Built-in...
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
177 people viewed this question
Top Dishwashers Experts
