Question about Irons
My psp 2001 steam press keeps beeping all the time and doesnt get up to temperature the light should come on when at temperature but doesnt keeps bleeping
Having same issue
Posted on Nov 27, 2012
Why does my iron contantly beep and no steam?
Hi Mary,
Check to see that your iron is set at a temperatures suitable for steam generation. Beeps are a usual signal to notify you that your iron is plugged and switched on but the temperature setting is low and cannot generate steam.
Oct 05, 2014 | Irons
I have a swan steam generator iron .s14030n .i have read manual and the steam only works if i keep pressing pump .should the steam come through all the time .when switched to steam .i have done the pu
MINE IS LIKE THAT. PRESS FOR STEAM WHICH CONTINUES FOR A SHORT WHILE. BUT IT IS A PAIN AND TGHERE IS NO WAY I HAVE FOUND ROUNBD IT EXCEPT A SPRAY BOTTLE WITH WATER!
Jan 28, 2013 | Irons
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
Good day I have an euro pro iron and it leaks all the time leaving water on washed clothes.also it leaks out of the bottom??
The water may come out at the bottom instead of steam. this is due to insufficient heat produced. So switch on your ironbox and keep it in full temperature using the knob. then the water will be coming out as steam and not as water itself. Try again.
I hope this is useful to you
Thanks
Jun 27, 2010 | Sunbeam Euro Press 4045 Iron
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Irons Logo
560 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
