How do i cahnge the dc socket as laptop wont charge with lead in.
  • 604 Answers
First make absolutely sure that the issue is the dc socket, is your power supply ok? if you have determined that your supply is good, the getting a new socket installed on the laptop is very labor intensive and therefore costly. It will cost you appx. 80 dollars to get the dc socket replaced.
Posted on Mar 19, 2011
    President:
  • 1,623 Answers
You will need to disassemble the laptop take the circuit board out desolder the old power connector and resolder a new one. As you dont state anything about exactly what laptop it is, thats the most info i can give
The battery wont charge for my lt2802u
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2013 | Gateway Lt2802u Laptop/notebook
Samsung NP-R480L laptop not charging. Possible DC-in
Mar 02, 2013 | Samsung N Computers & Internet
Loose dc connector Sony VAIO
Jan 28, 2013 | Sony VAIO Computers & Internet
Compaq celeron B830 WINDOWS 8 BATTERY NOT CHARGING
It seems a few guys on here are missing the point, if you wish to check to see if you dc socket is faulty you need a good working charger and a multimeter set to DC volts.. Remove your battery and inside the battery compartment there are a series of brass looking contacts some are longer than others, the longer ones 90% of the time represent the Negative ( -V ) or Ground, Connect your black meter lead to one of the longer terminals and continue to probe your red lead on the other smaller terminals and see what reading you get.. if you see a small voltage thats dropping this normally means you are on the pins that connect to the output of the battery and as such capacitors on your main board are discharging (hence the voltage drop). if you see 3.3v on some pins this indicates the charging voltage and shows your dc socket is in fact working fine and that the problem is with your charging circuitry on the main board which is where i am at the moment, trying to find the relavant information to allow me to repair it, LOL hope this helps..
Jan 06, 2013 | HP Compaq Presario Cq58 250Sa 15.6-Inch...
I have lenovo 44463fg laptop why it is not charge do you tell me the charging ic name thanks
Nov 07, 2012 | Lenovo Computers & Internet
My computer wont charge. i think the internal power supply of the pc is broken.
Nov 06, 2012 | Sony VAIO CS Series Notebook PC...
Hp pavilion entertainment pc wont charge or turn on
Check the charger is throwing out the correct voltage at the DC jack
Do you get any lights flashing at the charger? If you do it indicates that power is not completing the circuit and is being "spat back". This would indicate a damaged charging circuit or possibly a loose power jack socket, if it feels loose as you plug it in, you may need to change the DC socket
Jan 03, 2011 | HP Computers & Internet
My laptop wont turn on or charge i bought a new charger and it still wont work how can i fix it?
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jul 07, 2010 | Computers & Internet
Wont charge from a wall socket
the AC to DC adapter might be out of order, check it up
Apr 09, 2010 | Philips SA5245/02 Digital Media Player
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Computers & Internet Logo
David Payne
David Payne
