Question about Microsoft Kinect Sensor for XBOX 360
I bought the xbox Kinect and I have a media room so the xbox is in the back of the room and TV in front. I got two 10 ft extension cables for the kinect sensor, but it will not work. I can get the light to go on and pass the sound test, but then it will tell me that it is not getting signal. Are the two cables so long that there is no signal? Help! Alex
    President:
  • Microsoft Master
  • 1,623 Answers
You need at least 4m from the kinect to you for it to function correctly, if you are nearer than that you can try putting the kinect higher up which will gain you some distance
Posted on Mar 19, 2011
Can I make my Xbox 360 kinect sensor wireless as I would need a really long cord to plug it in
Sorry but no. You can pick up a Xbox Kinect extend link cable. There is a 15 foot cable for $19.99 usd. Try this site. Xbox Kinect Extend Link Cable
Dec 05, 2014 | Microsoft Kinect Sensor for XBOX 360
Xbox kinect has red light with no message on tv
Hello, this is a first for me. I have yet to come across a Kinect with a problem. A quick search and I see that it's actually kind of common. From what I can find, and after a few calls, it seems the only solution I can find is this at xbox support. It seems to say it could be the cord or the power outlet or simply needing an update. From the Kinect, the cable should go to what looks like a splitter. There should be a little green light on it. If not, it may not be getting power but the red light would come on powered from the xbox itself which is not enough to power the Kinect of course. Try to plug the Kinect into another outlet. They say the xbox and Kinect are not suppose to go to a power bar, surge protector or extension cord. I know that sounds crazy but it's true. If another outlet works then you know it's just the outlet. If that doesn't work, can you borrow another cable from someone to try, that can eliminate issues too. If the other cord works you know that's all you have to replace. The other thing to try is putting a Kinect game into the console and see if it asks you for an update. That could be your issue too. Try these and if none of them work, I would think you need to replace the Kinect cables. Hopefully it's not the Kinect itself. If these don't help, you will most likely need a repair or the connect will have to be replaced :( I hope this helps, let me know.
Dec 01, 2011 | Microsoft Xbox 360 with Kinect
The problem with the kinect is C000022D
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-5.aspx Red light on the Kinect sensor Last Modified 4/22/2011
Page Content kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive one of the following errors:
A problem has occurred with your Kinect Sensor (C000022D)
A problem has occurred with your Kinect Sensor (C00000C2)
Here's what to do to fix the problem:
update_error.jpg Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update.
If you still get the same error message, try the next solution.​ ​ ​ Solution 2: Check the cables ​ ​new360cableconnect.jpg
Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  5. Turn on the console.
If these solutions do not solve the problem, please contact Xbox Support
Jul 19, 2011 | Video Game Consoles & Games
How to connect the xbox kincet
If your Kinect only has one cord coming off of it, that should go into the back of your Xbox where there is a color coded slot (orange).
Feb 28, 2011 | Microsoft Xbox 360 Console
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
My xbox kinect game freezs whenever i try to play.
if you are standing in a good zone then that means you really haven't got enough room.If you move your snsor wilst playing it will probably freez,it does some times or the kinect cable is not pushed in far enough.
thanks for reading.
Jan 16, 2011 | Video Game Consoles & Games
Does a bluetooth earpiece work for a xbox 360 kinect
No a bluetooth headset will not work with the Kinect. The Kinect has a mic built in to the unit to pick up sound from the entire room.
Thank you for using FixYa!
Dec 30, 2010 | Microsoft Kinect Sensor for XBOX 360
Kinect
Troubleshooting Kinect audio problems Page ContentBelow is a list of common Kinect audio problems along with suggested solutions.
If you are experiencing...
Try this...
An echo
  • Turn off digital effects on your audio receiver. Digital effects include things such as reverb, compression, and synthesized surround sound modes.
  • If you are using a TV and an audio receiver at the same, turn off the volume on the TV.
  • Use the Kinect Audio Tuner.
  • If you are hearing an echo during Xbox LIVE gameplay but not while you are playing offline, the problem might be with another player's Kinect sensor. Ask the other player to run the Kinect Audio Tuner.
No sound from one or more speakers
  • Make sure that the Xbox 360 A/V cable is properly connected to your audio system.
  • Make sure that all speakers are connected to your audio system.
  • If your audio system has speaker switches, make sure that the switches are on.
  • If your audio system has a receiver mode, make sure that the setting matches the number of speakers connected. For example, If you have Use this mode Two speakers Stereo Five speakers and a subwoofer 5:1 Seven speakers and a subwoofer 7:1
Kinect voice commands are not working
Run the Kinect Audio Tuner
Your friends cannot hear you during chat
Make sure that the chat microphone on the Kinect sensor is on. Here's how:
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Kinect Settings.
  3. Select Chat Microphone.
  4. Select On.
Dec 11, 2010 | Microsoft Xbox 360 Console
Microsoft Kinect Sensor for XBOX 360 Logo
176 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
