Question about Philips 32PFL3403D/27 32 in. LCD TV
Please, answer me: is 32 PFL 3403/12 provided with DVB-C? Thank you for the answer. Matija Horvat, MD
Why would someone add an aftermarket ballast resistor to a 6 volt '37 Chevy MD field resistance lug on the headlight switch ?
hello this is James Auto.Repairs
welcome good sir I will do my best to help you resolve your issues with your repairs.
Here is the best answer I can give you
Please refer to the link provided below and you should find all of you answers there my friend good luck on your repairs
Please I ask if any of this has helped you in your repairs to please rate my answers accordingly thank you for helping me to help others.
38 Chevy 1 2 Ton Headlight Switch Chevy Trucks VCCA Chat
Sep 08, 2014 | Cars & Trucks
Information comToshiba 32in TV
What is the repair that you wish to do with this TV? Provide more details, please. What is the problem that you faces with this TV now? If you wish to get some details, check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 13, 2013 | Toshiba 32AV615DB 32-Inch Lcd Tv Dvb-t...
Philips pfl6007 power blinks 2 times
If power supply regulator board has any fault, this kind of blinks will occur to Philips brand TVs. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter". Blinking codes and details to Philips PFL series TVs are described in detail.
Apr 14, 2013 | Televison & Video
I used thomson dvb 160 decoder in ghana ,and i can only hear audio sound .why and i need an answer please.thank you
if you have an extra cable cord tried to replace then hooked up with other component input of the tv. let see if you can get a picture there.
Nov 05, 2012 | Televison & Video
I cannot install terrestrial digital tv on my Philips LCD TV 32PFL5403D/10 and it states that it has a digital tuner installed.
DVB-T can be translated in Mpeg 2 or H.264 (Mpeg4) format. Check if you have correct tuner installed for you local provider
Jun 02, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
Phillips lcd 32 inch(PFL-3403) tv picture is going off after 10- to 15 minutes of working since 26.01.2011.
Check whether timer is ON mode or OFF. If it is ON set it to OFF mode.
Check whether sleep after 15 mins is after
set it to NEVER or OFF mode(sleep means if you won't change any channel or iuf you din't did any thing for 10 it will goes to sleep mode..... and again you have to turn it ON)
Thank you
Jan 27, 2011 | Philips Televison & Video
Problems with code
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5C 01
KEY 00 = D4 A3 5D EB 7B F3 69 59
KEY 01 = 27 77 A1 FC 8F 9D 34 76
TELEWEST KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5A 01
KEY 00 = C0 F6 61 87 91 F9 67 57
KEY 01 = F0 83 35 E5 28 40 49 B2
PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
PROVIDER CODE: 54 01
KEY 00 = 3F B8 36 62 72 E5 E2 76
KEY 01 = 35 5E D6 40 6E AA 99 41
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
Dec 07, 2008 | StarTech.com StarView SV211K 2-port KVM...
Philips 32PFL3403D/27 32 in. LCD TV Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
