Question about Sony SLV-740HF VHS VCR
VHS will not accept a tape?? - Sony SLV-740HF VHS VCR
  • 22 Answers
YOUR VCR MECHANISM IS NOT WORKING, IN THE BACK, TO REPLACE A NEW RUBBER BELTS
Posted on Mar 19, 2011
My VHS player will occasionally accept the vhs tape but then it pulls out the film then turns off or ejects the tapes how can i fix it
Unfortunately there is some damage to the drive mechanism of the VCR. This will need to be fixed. I can't say what is causing it, but it is clearly not pulling the tape back inside the cassette before the eject action takes place.
Mar 18, 2017 | Emerson 4-Head VCR Video Cassette Recorder...
Roxio vhs to dvd not receiving video signal
this is because some VHS players have copy protection. for example some VHS manufactured by disney has copyright protection and is imposible to be compied to a DVD format.
Feb 06, 2012 | Roxio Easy VHS to DVD for PC
A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Jun 01, 2010 | Televison & Video
VCR Not Accepting Certain VHS Tape
I had this happen once and all I did to correct it was to fast forward it just slightly or manually wind it past the leader strip (the clear or white part at the beginning). To do it manually, there is a small hole you must insert a toothpick (or something else as small) to push the pin in and then advance it with your finger while holding the pin in. Hope this helps.
Oct 15, 2008 | Philips Magnavox DVD/VCR Dual Player
Emerson vcr won't accept a tape
Yes, it can be fixed, but the cost may not be worth it.
There are several components which may be the problem, ranging from a gear, a sensor, the load motor, or it may even require replacement of the entire cassette loading assembly.
Without an inspection, it's impossible to tell exactly what the problem is, or likely cost to repair.
It may be much cheaper to replace the machine.
Mar 24, 2008 | Emerson EWV601 S-VHS VCR
RCA VR688HF VHS VCR won't accept tapes
The brain in a VCR has a little switch assembly that senses what position all the mechanical stuff its in. Apparently, the mech is out of whack which is why it won't let you play. This is a common problem and any VCR shop should be able to repair it.
Dec 22, 2007 | RCA VR622HF VHS VCR
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Machine not accepting tapes
Just a thought : check if the head isn't blocked ! It should rotate freely (without any friction). I had more or less the same phenomenon (my VCR wouldn't accept any tapes and nothing was activated if I "pushed " a tape in). The reason was here that the VCR wasn't used for a long time (a few months), but it was plugged in all the time (heated up the interior). As a result the head was a-kind-of-blocked. Nothing serious, since I rotated the head manually my VCR works fine.
Feb 08, 2006 | Panasonic PV-V4611 VHS VCR
Sony SLV-740HF VHS VCR Logo
139 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
