My sister has a Luxor V19LCDDVD875 TV from ASDA 8 days after warranty expired it developed high brightness. Reduce brightness and store works until next boot when (although the setting value is as stored) the high brightness returns. She has no user manual, it came without. Any help you can give much appreciated.
  • 3 Answers
SOURCE: LCD TV picture screen very dark
I have the same issues with my Westinghouse LCD set. I've found that going into the settings (using the TV remote) I can get it back to a bright picture by selecting 'restore factory settings'. It is aggravating and a pain, but I can correct it.
It only seems to do it on the analog stations, not the digital (HD) ones, so maybe it will go away after the conversion next year.
Hope this works for you.
Posted on Jul 31, 2008
  • 3 Answers
SOURCE: Vizio 47" Costco hdtv has red floating areas!
After posting this problem we did call Vizio. They sent out a repairman (had to wait over a week) who fixed it by: Replacing the LVDS cable and the main board. (Just like somebody on this blog wrote somewhere!) We also had just previously called our cable company who came out (also free) and checked our system only to find the cable running around the house to the tv needed replacing as it was sending zillions of errors. The red flowing problem (called "red pixilation") was due to the Vizio LVDS cable and main board being faulty from the factory.
Just want you out there in web land to know how to get your similar problem fixed!
Posted on Jun 14, 2009
SOURCE: SAMSUNG LNT3232H LCD TV FLICKERING BACKLIGHT
I have a ln-s4092d that had the same problem after a little more than a year of service. Replacing the main board seemed to fix the problem. But about a year later, the same problem has reappeared. I'm getting ready to replace the main board once again, but I don't really want to do this on an annual basis/
Posted on Aug 14, 2009
  • 33 Answers
SOURCE: Bought Memorex MVD2059D 20
IF the Standby Red Light does not come on when you plug in the TV:
1) Check fuse on back panel next to power cord. Pull out cord and pop fuse holder out. On an ohmmeter, it should read 0(short)-that is a good fuse.
2) Check the fuse on power supply board next to power connector. It is soldered onto board.
3) Be careful with this step: With all boards screwed in place, plug in TV and then unplug it. Next take a Voltmeter set on 200 Volts and test large electrolytic cap in middle of board-should have @100-200 volts on it. Do not short the capacitor-big fireball flash explosion if you do!
If 1-3 test OK, then:
D10 is shorted. HER304 in middle of Power supply board near large electrolytic cap. Replace with same diode or Radio Shack 276-1144 3A 400PIV Diode. PLEASE BE CAREFUL WITH HIGH VOLTAGE PRESENT ON POWER SUPPLY BOARD. UNPLUG POWER CORD!!! OBSERVE PROPER POLARITY WHEN REPLACING DIODE-LOOK WHERE THE BAND IS.
Posted on Oct 06, 2009
SOURCE: how to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Posted on Nov 14, 2009
I HAVE HAD MY LUXOR 52 INCH FLAT SCREEN TV ,BOUGHT FROM ASDA APROX 5 YRS AGO,,, IT HAS NOW STOPPED WORKING,,, THERE IS SOUND BUT NO PICTURE
Did you shine a flashlight behind the screen to see if the image is present, if so the backlight is burned out.
Apr 20, 2017 | Luxor Televison & Video
My Netflix app has gone from my Luxor tv. It was there a few days ago How do I get it back. I have searched but it just says no app
Go to the "app store" associated with your tv, look under movies, and then reload the app. Put in your password and you are back in business.
Apr 01, 2016 | Computers & Internet
I have a Luxor 19" TV from ASDA Mod: Lux-19-914-cob.
There are two possibilities:
1. channel memory is retained by an internal battery, which has died and needs to be replaced;
2. channel memory is retained in a memory chip, which for some reason is not functioning properly or has failed.
Either way you're going to need to fix something inside the set. TVs are so inexpensive today, you're better off buying a new one.
Sep 03, 2014 | Luxor Televison & Video
NEED HELP BAD. Luxor TV (Asda) keeps resetting my settings when turned off and on!
Main system control memory IC fault. Contact any service technician to replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | Luxor 19822 COB
I recently purchased a lg 42ld400 a few wks ago and can't seem to get the picture clear when I saw it n the store it was clear and bright with excellent color while few of my channels are good most look a...
Go into the tv menu.Tries all setting resetting to factory setting,best result.No high backlight setting will not shorteen LCD screen panel life.It design for life span of 6 to 8 hours of tv viewing in 7-8 years at least.The store probally have high end HD satalite signal.U just have basic cable signal only,am i wright?
Dec 17, 2010 | LG Televison & Video
Do akai still manafacture Luxor televisions if not
As per the information i found , Akai is the one whom you need to contact.
The Contact Details are :-
USA AKAI CUSTOMER CARE
cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-726-4405cb_transparent_r.gif
Hours of operation (Eastern Time):
8:30 am ~ 9:00 pm (Monday through Friday)
9:00 am ~ 5:00 pm (Saturday)
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Televison & Video
TV UNDER WARRANTY & NO RESPONSE FROM DEALER JAN.6,2009
All too often, extended and third party warranties are not honored as they should be. Some are even totally worthless. The general plan of a lot of third-party warranties is to hold the customer off until the warranty expires, and then deny it. If this was an extended warranty through the Rex store, then consider talking to a lawyer as soon as possible. One letter from an attorney may be all it takes. Or even the threat of going to an attorney is enough some times. It is a legally binding agreement that expires, so once it is up, they will almost certainly deny your claim.
Almost all extended warranties have a time frame for repair, and more specifically replacement! If they cannot repair the TV within a certain amount of time, then they should replace it.
I hope this helps you...
Jan 06, 2009 | Televison & Video
27pt9015d/37
to a repair shop, I mean what else can you do but throw it out or pay.ebay
Jan 23, 2008 | Philips 32PT6441/37 32" TV
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
