Question about Gigabyte GA-K8NF-9 (890552602964) Motherboard
BIOS problem I obtained a virus from the internet, and now i cannot detect my harddrive. Also i tried to update the bios but it gives me a message saying "file size incorrect"... VIRUS DESCRIPTION Virus obtained trough internet as an exe file. AVG 7.5, Norton 2005 and Avast 4 did not detect the virus as an exe file. When the virus had taken control of the pc it started to end programs like Norton and AVG and it also opened a DOS window and changed something. It also changed files from the registry. The virus changed the desktop and also made that I could not access my hard drive. It was not showing in my computer or on the start menu. My Documents and pictures shortcuts in the start menu were also removed. I searched the pc with ?Spyware Doctor? and it found a few file including ?Vurtoamonde?. I removed it but it kept on returning. Windows then began giving warnings about a virus; it described it as an worm that spreads by file or email, sending itself. Although after the PC was restarted; Avast detected a virus, in deferent folders including the Windows folder, it and could remove it before Windows started again. This did not remove the effects that the virus had on the PC, also after formatting the hard drive it cannot be seen by the PC to boot with.
  • 2,028 Answers
O.k. start by making a bootable disc or diskette to flash the bios with. This should get the machine to recognize the drive. If this is what you did before, do it again, because something didn't download or come out right on the disc. Once you've done the flash, if the hhd still isn't recognized then most likely the virus has done it's damage and the hhd is shot. Just a piece of advice, run only one antivirus, I recommend AVG, it's all you need for antivirus, spyware, and adware, the new 8.0 version is right on. With antivirus, the more the merrier, IS NOT the case. You actually made your system more vulnerable by having several antivirus along with spyware. The antivirus companies have made them to recognize other antivuruses as a threat. So, they conflict with each other, and can't do their job.
Posted on Aug 02, 2008
"disk read error occured". After
This can be indication that your Harddrive is not being detected by the system. You can try loading the defaults in BIOS or re-detect your harddrive automatically. See if it is listed in the boot devices in BIOS. You can also try to check if power is correctly supplied in the harddrive. Open your CPU box, take out the cables (especially the molex) for the harddrive and put them back in firmly.
You can try to use the 32 bit harddrive diagnostic of dell to check if your harddrive is still working or not. Here's a guide: Click Here
Hope this helps.
Aug 05, 2011 | Dell OptiPlex GX260 PC Desktop
Laptop says no operating system found wot do i do as its a samsung notebook
Check if the harddrive is detected in BIOS (Basic Input/Output System) setup by pressing F2..or F12 (depends on what key is designed for the BIOS setup).
- If the harddrive is detected in the BIOS (usually shows the harddrive name or values beside "Drive 0"), your operating system is corrupted. You need an operating system disc to install it.
- If the harddrive is not detected in the BIOS ( no value beside "Drive 0"), either the harddrive cable is loose, the harddrive is not inserted properly or is defective. Check the harddrive compartment at the bottom of the laptop and use screw driver to reveal it. Try to reinsert it or use a good known hard drive.
Hope this helps.
Jun 10, 2011 | Samsung N150 Notebook
Lap top can't find hard drive
Here are some steps that you can try.
- Check if the harddrive is recognized in the BIOS (Basic Input Output System). Normally you will see values beside "Drive 0" at the first page if the harddrive is detected. If it says none or blank, then it is not detected. Reload BIOS default settings and try to boot up the unit to see if it will pick up the harddrive.
- If the harddrive is not detected in the BIOS, you need to unscrew the harddrive compartment at the bottom of the laptop.
- Reinsert the harddrive and check harddrive cable. Also try to use a good known harddrive if yours is defective.
Hope this helps.
May 27, 2011 | Samsung Notebooks 14.1 W P460 Professional...
I am trying to install a different harddrive on my P5S-MX SE motherboard. The bios post message says it's not detected.
Go into the BIOS and change the SATA mode to Compatible, then save the BIOS and restart now it will start detecting.
Mar 09, 2011 | ASUS Computers & Internet
Hello I have a LENOVO-Y430 laptop, suddenly my laptop stopped functioning, It gets stuck in the STARTUP LENOVO SCREEN, I get two options in the bottom of the screen, press F2 for SETUP & Press F12 for...
Welcome to Fixya
Make sure first that there are no devices plug in to the usb when you boot up the computer. Check if the harddrive is being detected by the computer. Press F2 to go to BIOS menu and see if the computer can detect you harddrive. It should be under the main menu and will say below harddrive. It should give you infromation of the harddrive. If there is no information of the harddrive then the problem there is the harddrive already.
Please reply to this email for any update.
Thank you for using Fixya!
Feb 02, 2011 | Lenovo IdeaPad Y430-3231U Notebook
I have a seagate barracuda 7200.10 and my computer would not detect it .. it tells me to install driver for the harddrive which i dont have
Dear friend update your bios to detect latest hardwares .......u can find bios update on official websites of your motherboard ...........rate me if its helps u........
Nov 28, 2010 | Computers & Internet
Bios updates?
Sometimes bios updates be a costly when you have entered wrong or improper bios.
Obtain bios update from the computer or motherboard manufacturer.
Keep your booting process from the CD ROM.
Bios updates are downloadeblle from the internet and to perform as the diskette.These diskette are used as the reboot it.
It boot from the CD ROM and give command to install or update.
Dec 05, 2009 | MSI RS480M2-IL Motherboard
I had installed one software that was bios update after installation that software Hp pavillion dv2000 bios configuration had chage. how can i solve this problem now my laptop cant detect the harddrive. it...
Restart your laptop, and immediately press DELETE to enter BIOS setup. Select "Load BIOS Defaults". Navigate through the menus;
you should see "auto-detect disk-drive". Run that utility.
Save the updated BIOS settings, and exit from BIOS-setup.
If all else fails, take the computer to a qualified technician.
It's probably just a 10-minute "fix" for an expert.
Nov 20, 2009 | Dell Latitude D600 Notebook
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Gigabyte GA-K8NF-9 (890552602964) Motherboard Logo
122 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
