Question about Bosch Axxis WFL 2060 Front Load Washer
Need diagram on how to install boot gasket on WFL2060UC
Water is leaking from Bosch washing machine WFL2060UC. Checked the hose connections. Lots of water comes out of drain hose after one cycle and water is pooled in the pump (place where the cap is next to...
Bosch washing machine WFL2060UC This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 13, 2011 | Bosch Axxis WFL 2060 Front Load Washer
I have a frigidaire front door load washing machine. I was trying to clean the bellows but the inner (circle) spring fall out of the bellows. How do I put it back thanks serial number is BLTF1040D
Hi.
If you are talking about the circular tub boot spring, then you need to remove the gasket. Pulling out the spring is very easy, refitting is more complicated.
It is held by a clamp or clips, or both (this one has clips as well). Remove it and refit it. To remove the bellow, depending on the model you may need to remove the front panel. I think on this one you need first to remove top and control panel. When you have free access to the gasket, remove the gasket, fit gasket following the tube edge, align the gasket correctly (the soft rubber bellow), then refit the circular spring.
Here diagram, click on the picture to enlarge:
Check also this manual at page 29.The manual is for a similar Electrolux and shows pictures of bellow and spring refit, which is what you need to do.
Regards.
Ginko.
Apr 10, 2011 | Frigidaire Washing Machines
Replaced the sump pump, now the machine will not
There will almost certainly be something stuck in the pump again. Possibly the same thing that happened to the last one.
May 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How to replace the head gasket for a toyota truck 4x4
I assume you have never replaced a head gasket, if you have to ask? Or, do you just need help now you have it apart?
Feb 08, 2010 | 1998 Toyota Tacoma
Door gasket is ripped and water is leaking. i need a part number for new gasket and possibly a diagram of disassembly. washer machine no. wcvh626ofww
you can buy your door boot seal from Repairclinic.com #1394050 cost is $ 98.05 or try your local appliance shop!
Jan 19, 2010 | GE WCVH6260FWW
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
I needs to replace my refrigator door gasket. I need a manual with pictorial diagram and with details on how to remove and install the gasket.
open door and pull on inside of gasket to expose screws or 1/4 nuts.. loosen[do NOT remove] all screws and pull old gasket out. place new gasket in sink of hot water to soften it and put back around door. snug up a couple of screws on each side and test seal by shutting door..you may need to adjust inner panel until just right..then tighten all screws
Sep 05, 2009 | Refrigerators
Air compressor head gasket diagram
Campbell hausfeld has all their manuals on line at www.chpower.com / you can enter the model # of the whole unit or just the # of the pump. Also you can enter just a partial number example wl650 for a list of models is that range. Use caution when installing gaskets for chpower oiless pumps. Some of their gaskets are very brittle. After installing parts, turn pump by hand to make sure all parts are in their proper place and that there is suction. Enjoy
Dec 02, 2008 | Campbell Hausfeld 26 - Gallon Air...
Mold on boot gasket--how do I change boot gasket?
If old one is not leaking ,fill machine up and put cup full of bleach in let it wash for 5 mins ,Then switch of leave overnight,then contine with wash cycle.This is because most people do not do hot washes ever.
Oct 11, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
49 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
