Question about Refrigerators
Now ,compressor didn't work but coil's contnuation test are good,the reason is why ?
  • 22 Answers
There are two reasons, if the gas is over loaded or the gas is blocked
Posted on Mar 19, 2011
04 navigator is blowing ac fuse 11, ac coil shorted, 3 different coils, can ac compress short the coils
How did you hook up the inline fuse to compressor and ground to compress ? Ground what ? Right at the clutch coil ? You have to be hooking it up wrong . The compressor can't cause the clutch coil to short or blow the fuse , even if the compressor were seized up . An before that would have the serpentine belt would burn up , squealing noise. applying B+ voltage in the relay socket ,pin 30 to pin 87 will engage the compressor clutch . If the fuse blows the wiring from the relay to the compressor clutch is shorted to ground . Look for rubbed through wiring harness .
Jul 14, 2017 | Ford Cars & Trucks
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Fridge and freezer not staying cold
You didn't give age, make or model of your fridge, but I have found on two, made in the last 15 years that the newer models have a solid state starter switch on the compressor, and they don't last like the older coil-magnetic starters. They are a fairly cheap fix at around $50.00. Ask your repairman to test the compressor with his universal starter/capacitor most carry with them. Keith L.
Mar 02, 2012 | Refrigerators
TEST COIL PACK TO SEE IF THAY ARE FIREING
on the straight six you will remove the bolt holding each coil to the valve cover. Remove one coil and use either a spark tester or a test light. If there is spark the coil is good. If there is no spark swap that coil with another. If the swapped coil fires than you know the circuit is good. If the coil that didn't fire still doesn't fire than you know the coil is bad.
Did that help?
If you have any questions let me know.
Oct 06, 2011 | 2002 GMC Envoy
Hello, I have a duo therm ac unit, the fan works fine in all the Fan only speeds, but when the ac is selected, the compressor comes on and the fan drops down to less than half speed. you can hear the fan...
Check incoming voltage circuit and wiring for proper gauge wire etc, and have compressor start capacitor tested, or replaced. I'm curious as to why circuit breaker didn't trip in panel when compressor causing so much current draw, that's reason for checking wiring etc to AC circuit.
Sep 14, 2011 | Dometic Rooftop RV Air Conditioner
My Amana refrigerator just stopped cooling the lights work there is air blowing but not cool...what can I do?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons The fan or blower has failed. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again. The second reason can be more difficult. 1. The timing device that runs the defrost cycle of the refrigerator is defective. 2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good. The timing device can be an advanced defrost control board or a mechanical timing device. If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things. The fan or blower The timer device The electric heater coil By methodically checking these parts you can isolate your problem and fix it.
Good luck in solving the problem....
Aug 07, 2011 | Amana ABB1927DE Bottom Freezer...
AC is running but not cooling the house. It is a Payne unit. Changed the filter but didn't help.
Make sure the outside unit is working, both fan and compressor inside. If both of these are coming on and working, then your problem would more than likely be low/high refrigerant charge. You can also check the air flow inside and make sure it's blowing normal. Weak air flow can point to a dirty or clogged indoor coil which would have to be cleaned by taking the cover off of the coil, possibly moving flue vents out of the way, and taking the small cover off of the inside coil depending on if it's a upflow or downflow system. Hope this helps or at least points you in a better direction, good luck!
Jul 03, 2011 | Heating & Cooling
Will not cool, freeze or reset. Model # RFG293Ha
Top of Form If there is no coolingat all , before we go further we must confirm the first step of confirming thecompressor and gas pressure. So shut off the fridge and leave it off while youclean and check the evaporator for frost. If frost is seen it is a goodindication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happenin about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer andfridge. If there is no ice formation we have a big issue as the compressor andgas must be checked out. If compressor is running check the pressure, get helpto test gas pressure. If not you will need to fill up ,If gas pressure is goodthe possibility of the compressor being inefficient is high. In such a case youmust take consensus to estimate and decide, if RPM of motor is low checkcapacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling tocontinue and the fridge to cut off . If not the auto defrost timer, or thethermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shutsif the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come tothe solution.
Jun 28, 2011 | Samsung Refrigerators
A had a new compressor installed and the air worked for about a week and then it began blowing luke warm air
When the compressor was replaced you should have had anew dryer and expansion valve put in, Most places wont warraty the compressor with out them. Also the shop should have done a vacuum test on the system to make sure you didn't have leaks. This is what it sounds like is happening to yours. Sounds like someone didn't do thier job correctly. Call your mechanic
Jun 22, 2011 | 2005 Jeep Liberty
My Kenmore refrigerator model #10657026600 side by side, the refrigerator side dose not get cold...the freezer side works great. please help. thank you.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
  2. The timer device
  3. The electric heater coil
Take care.
Jul 20, 2010 | Kenmore 60721 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
