Question about Dell TrueMobile 1184 Wireless Broadband Router (802.11b) 9U555 (9U555)
Security I do not know how to password protect my wireless internet using our router. Can you tell me how? Kathy
    Genius:
  • 1,269 Answers
Hi.
Do the following steps
1. Open Internet Explorer, type on the Address Bar type http://192.168.62.1
2. You should see a box prompting you for your username and password. Enter your router username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.
3. Click on Advanced Settings tab at the top, then go to Advanced Wireless tab at the side. There you can enable wireless security. Choose WPA-PSK or WPA-Personal and type your desired password then save or applythe settings. That's it.
Posted on Aug 02, 2008
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
My local public network is asking for a security key number
Probably as is open and with no security some one change the wireless setting adding security to the router, Reset the router to factory settings and add a password to reconfigure the router not to the wireless connections, in that way people can still use the public internet but cant configure the router because dont have the password.
Mar 12, 2011 | Computers & Internet
Cant connect to the internet wirelessly. I get a prompt telling me that the password has been changed.
Uninstall The BELKIN ROUTER MONITOR FROM THE CONTROL PANEL
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 28, 2010 | Belkin Play N600 Wireless Dual Band Router...
Pasword protect my router how?
There are two kinds of password protection for your ROUTER;
(1) The Web Interface can be password protected by changing the default password
(2) The Wireless connection password (encryption)
Which one do you want enabled to protect your router?
Jul 27, 2010 | NetGear WGR614 Wireless Router
Wireless n 150 router, pin worked for two laptops, third laptop keeps saying invalid pin/password but i am using the exact same one i used for the other two, anyone know why?
On any of the Computers that are Getting the Internet
Open RSP By typing 192.168.2.1 on the Address Bar of Internet Explorer
On the Left Side Under Wireless Click Wi Fi Protected Setup
Leave the Password Blank & Click Submit
Disable it And Click Apply Changes
On the Left Under Wireless Click Security
Take a note of the Password ( PSK Or Pre Shared Key )
Now on the third laptop Try to connect Wireless
It Will Either Ask For the network key or the Security
key Type The PSK
And connect to the Network
Dec 26, 2009 | Belkin (F5D7230-4) Router (587009)
I've a Netgear router and I've reset it. Now I can't get it protected - it's working but without protection. What too do ??
Access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wi fi security then set WEP key it is your password to connect your wi fi.
So only those can connect who knows your password.
Let me know if you need more assistanse.
Thanks.
Sep 01, 2009 | NetGear WGR614 Wireless Router
How do i set a password to protect my wireless internet
Access the Router's page and go to Wireless configuration. You may assigned a WEP key that uses hexadecimal value (A-F, 0-9). So if someone attempts to access your Wireless network, they will prompt to enter a Wep key.
Jun 05, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Need to protect my wireless network!
you must logon to the NetGear wireless router and setup wireless security. choose a security type usually WEP, type a key phrase or passphrase and voila, you will have to re-connect on your clients by entering the password when you get prompted for it.
Jun 03, 2009 | NetGear WGXB102 Wireless Range Extender...
How do i password protect my router from outsiders connecting
Hi, check out the support pages here:-
http://kbserver.netgear.com/products/DG834G.asp
Select your model (v3,v4,v5 etc) then look at the setup pages. Set your security to WPA rather then WEP as this is easily crackable, and with WPA you can choose the password. You should also change the routers admin password to be extra safe.
Let me know if you need anymore help.
Dec 23, 2008 | NetGear DG834G Router
Protection on my Mac
Given that you have setup the Internet connection on your router, encrypting the wireless security will be fairly easy for you. Just follow these steps.
1. You should use you PC or MAC that is connected directly to the router via an ethernet cable. You can use PC or MAC, which ever is connected directly to the router (Connected thru cable not wireless).
2. Open Internet Explorer / Firefox (PC) or Safari / Firefox / Internet Explorer (MAC), then go to the address bar and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Leave the username blank and type admin as the password (**If that will not work, (Enter admin for both the username and password)
3. You should see the Setup page shown below :
4. Click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use your name or last name, or any name that you would like, because that will be the name of your wireless network, that will be the one that your wireless computers will detect) then click on Save Settings and then Continue when the Settings are successful dialog is displayed.
5. Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 64 bits 10 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. It Will generate 4 keys (Key 1-4). You will use key 1 as your password.
6. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed.
7. Now let your wireless PC scan for available wireless networks, find the name of the wireless network that you have specified earlier for SSID then connect to that network. Of course since the network is password protected, it will ask you to enter a password, this is time that you will enter the network key (Key 1 - password).
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Dell TrueMobile 1184 Wireless Broadband Router (802.11b) 9U555 (9U555) Logo
108 people viewed this question
Alun Cox
