Question about Tissot T-Touch T33159851 Wrist Watch
I have some problem with my T-TOUCH, the touch cannot available when i touch screen , hands also stoped at 2 O`clock and just the time on LED screen go very faster after changed a battery.
3 Suggested Answers
HW_Dude
  • 87 Answers
SOURCE: analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Posted on Jan 10, 2009
escapement
  • 2334 Answers
SOURCE: had battery replaced after 3 years.time is stuck
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals.Rate me, please
Posted on Mar 15, 2010
How to set the time on an Elgin Anniversary clock
If there is no special winder for clock hands at the back of clock movement, you have to adjust time by lifting the dome and moving hands by finger. Move MINUTE HAND ONLY clockwise until the desired time is set. In no circumstance touch hour hand.
Feb 24, 2011 | Watches
How to reset tissot t-touch after battery replace? I could not find the AC point,there is many points under the battery but not accsessible when the battery is inserted.
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Aug 06, 2009 | Tissot T-Touch T33159851 Wrist Watch
I need calibrate Tissot t-touch
Syncronisation sequence is in the user manual. syncronisation is as follows.. 1) Press T to activate touch system. 2)touch the screen centre to show units display. 3)hold T button for approx 5 secs till the hands point to 12o clock. 4)use the + & - buttons to control the minute and hour hands... you must syncronise them both to 12 oclock exactly. 5)when you have them both pointing to 12 exactly, press the T button to finish the sync. the hands will now go back to the time. If the hands often go out of sync, the battery is probably worn and will at some stage the 'bat' warning will appear. (this initially only flashes every 20 secs, so watch the display for over 20 secs to see the 'bat' warning. eventyually this becomes permanant display). Batteries normally last about 6 years
Jun 04, 2009 | Tissot T-Touch T33759851
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
On my Tissot t-touch expert, i need to know how to change
1. touch middle of screen till you see 24h Cm or 12h Cm
2. press middle button
3. top button changes Cm to Fft (celcius meters to farenheit feet)
4. bottom button changes from 12h clock to 24h clock
Apr 05, 2009 | Tissot T-Touch T33759851
Did you notice that this is TOUCH SCREEN? This is why you have just one resetting button. All the settings must be done using TOUCH SCREEN. So, Tap on appropriate icons on the screen and play with them till you find the right settings.
Unfortunately there is no instruction downloads available on the net, so, you have to find the way around yourself.
Rate me, please.
Mar 21, 2009 | Watches
Analogue hands don't correspode to digital clock
1. Activate Crystal
Jan 08, 2009 | Tissot T-Touch T33159851 Wrist Watch
Tissot t touch, time problem
you need to calibrate it.
go to the '24h Cm' screen [T button, then touch centre screen few times]
hold down T button for 5secs
use + button to bring minute hand to 12 o clock position
use - button to bring hour hand to the same place
press centre of screen and it's done!
Phil
Jun 29, 2008 | Tissot T-Touch T33159851 Wrist Watch
Synchronizing the manual and digital clocks
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock Incrementation of the minute hand(3 steps=1 minute) Incrementattion of the hour hand(3 steps=1 minute) Press the middle button to validate the setting.
Jul 06, 2007 | Tissot T-Touch T33759851
Tissot T-Touch T33159851 Wrist Watch Logo
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
